[HELP] Repair Arcam Alpha 2 - 240v - Page 4 - diyAudio
Old 1st February 2013, 07:57 PM   #31
BC546B and BC559C... a poor repair attempt by someone who did not know what they were doing....
I would agree - you might as well fit all new transistors as it is quite cheap to do so. You may use BC546/BC556 if they are easier to obtain, instead of BC547/557. You may replace all resistors with metal film (blue) as well.
I'd suggest mounting the resistors that are part of the VI limiting circuit (R31-38 and R131-138) spaced away from the pcb by 10mm - make a bend in the leads to support them.
C14/114 will have been a polystyrene 10pF capacitor. Polystyrene is now pretty much obsolete, so you may use a polypropylene or polyester film capacitor here, or a high stability (COG/NPO dielectric) ceramic capacitor. 1% tolerance or better. I notice again the previous repairer was an idiot and just used a regular ceramic capacitor to replace this part - this probably caused oscillation which caused the damage you have now!
Old 2nd February 2013, 09:20 AM   #32
CrustyD3mon's Avatar
I Was Checking the rest of the transistors on board...and i saw the following:
In Q(1)10 there is a BC557/C557
Q8/Q108 theres something only with mipcase letters :S
RThe rest of them are BC547
Do you think i should remove everything?
Old 2nd February 2013, 09:35 AM   #33
The two BC547 (Q2, Q3, Q102, Q103) in the input of the amp should be matched types.
Unless you meassure something wrong with those, leavbe them to be.
Probably is also the Q4, Q5 and Q6 also OK. Theese are less critical being matched, but always an advantage.
From Q7 and outwards I would change them all even if they meassure well.
Q1/Q11 is only for the muting. Leave them to be.
Q8 should be a MPSA056
If You can't get it, I have some here.
Sooner or later you end up with TANDBERG
Old 2nd February 2013, 09:48 AM   #34
Originally Posted by jaycee View Post
I could be wrong and the TIP2955 are genuine, but I cant find any ST datasheet that shows that they made them in a TO-3P package - only the original TO-218 package, and now the more modern TO-247 package. The only versions of them I can find that were made this way, are Chinese copies which are probably inferior quality.
Here: TIP3055 pdf, TIP3055 description, TIP3055 datasheets, TIP3055 view ::: ALLDATASHEET :::
Clearly states it has been produced in both TO-247-package as TO-3P
I must say I have had good experience with the Chineese so far.
Got good parts all the way.
Actually the only seller that have provided me with fake parts was from somewhere else, and that seller never was in sight anymore.
Bought replacements from China and I am good. (And for $9,- getting me ten transistors. Nice)
Old 2nd February 2013, 10:43 AM   #35
.....Bought replacements from China and I am good. (And for $9,- getting me ten transistors. Nice)
You are right about Chineese and even On-semi TIP3055/2955 being supplied in what was called SOT93 case.
The issue is, I think, about ST Micro product being in anything other than TO218 or TO247 packages.
That's either a plain metal tab or full plastic case. When you see a SOT93 case [similar to T03P(n)] labelled ST,
then also check old data sheets, you would also think "Fake".
Why the big deal with ST product? Well, some TIP3055 are no better than original 2N3055 spec, with Ft 800 kHz.
ST product exceeds 4MHz and distortion is considerably lower in 50W amplifiers I have built - lower even than
other branded TIP3055 products. I think that's what ARCAM were doing there, using something you wouldn't
normally consider suitable for Hi-fi.
Ian
Old 2nd February 2013, 10:58 AM   #36
A little bit late...i already remove every single transistor from both sides....:P
I will try to find Q8 here in portugal...i let you know if i can't get it....thanks!
So...this night i cover the holes with Araldite...not too much eyecandy...but i think will do the job...what do you guys think?
The big hole will be cover one more time before i drill the holes....
Old 2nd February 2013, 12:54 PM   #37
OK.
You should find two and two transistors to be matched to eachother for the position Q2 and Q3 (Q102 and Q103) at the least.
I would go for a complete match of both theese and the Q4 and Q5 in the input part of the amp.
Will secure as good sound as possible in the amp.
Actually the rest is not that critcal, as there is only singelstanding transistors who only interacts with its partner of opposite charge. (TIP2955/TIP3055, FST239/FST240, and so on)
Otherwise your repair seems to be fine. I would have used polyester for repair, but this is of only academic interrest. Looking good what You are doing anyhow.
Old 2nd February 2013, 02:01 PM   #38
The main reason to match the Q2/Q3 transistors is to ensure low DC offset at the output. To match them, use a hFE tester on a multimeter. Pick two transistors where the value is close as possible.
Q8 should be MPSA56 - made by either Onsemi or Fairchild. If you can find it, MPSW56 may be better - this is the same transistor as MPSA56 made by Onsemi, but in a larger 1 Watt package for improved heat dissipation.
Old 3rd February 2013, 09:24 PM   #39
OK.
Thanks for the advices....
Today i don't advance anything on this...but i'm planning get the list of components tomorrow...so based on your inputs i take some notes to try to find the right components...correct me if i'm wrong...but i think i list every single one that i need...i rebuild the previous list:
FUSES:
2x FUSE 2A/250v
1x FUSE 630ma T
LEFT SIDE:
Q13 -> TIP3055 (TO-218) or (TO-247)
Q14 -> TIP2955 (TO-218) or (TO-247)
Q2 BC547
Q3 BC547
Q4 BC547
Q5 BC547
Q7
Q8 MPSA56 - either/Onsemi/Fairchild or MPSW56 - Onsemi
Q9 BC547
Q10 BC557
FST239/240 replacement-> ZTX653/753
Q12
Q11
R28
R35
R37
R38
R39
R40
D1
C14 polystyrene 10pF capacitor or polypropylene/polyester film capacitor, or (COG/NPO dielectric) ceramic capacitor 1% tolerance
C15
C16
RV1 -> Iskra 1k
RIGHT SIDE:
Q113 -> TIP3055 (TO-218) or (TO-247)
Q114 -> TIP2955 (TO-218) or (TO-247)
Q102 BC547
Q103 BC547
Q104 BC547
Q105 BC547
Q107
Q108 MPSA56 - either/Onsemi/Fairchild or MPSW56 - Onsemi
Q109 BC547
Q110 BC557
Q112
Q111
R128
R135
R137
R138
R139
R140
D101
C114 polystyrene 10pF capacitor or polypropylene/polyester film capacitor, or (COG/NPO dielectric) ceramic capacitor 1% tolerance
C115
C116
RV101 -> Iskra 1k
Old 7th February 2013, 01:37 PM   #40
Hey Guys,
Some difficulties to get the material here in Portugal :S
any link for a none fake TIP3055 and TIP2955 ?
and for ZTX653/753 as well ?
Arcam Alpha 3 Carlosraj Solid State 2 3rd October 2011 07:23 AM
Arcam Alpha plus v. Alpha 5 plus v. Rotel RCD 855 dynoPort Digital Source 1 30th March 2011 11:19 AM
Arcam Alpha 8R repair advice tmr510 Chip Amps 1 12th September 2010 07:46 PM
Arcam Alpha 7 Repair big jim Solid State 1 26th June 2006 02:10 PM
Arcam Alpha 8 ManUtd Digital Source 4 5th April 2004 02:23 PM
Copyright 1999-2017 diyAudio
