#11 | |
#12 |
All the Araldite and tissue will be doing is rebuilding the "plastic" of the PCB.
In days gone by PCBs were made of layers of Resin and Fibre. |
#13 |
#14 |
You should also check Q8, MPSA056 and R27 (56R), and Q7 FSWT239 and R30. If theese are blown, and as Jaycee says, the FST239/FST240. (Q11 and Q12)
Ah, My component-references are to the AII-schematics. I will have to look a little closer on Your pics. Seems as if you only should add 100 in fromt of the references I wrote here. Especially Q107 looks suspicious on the pic over here. But thees E-line transistors often look as if they have been overheated all the time. Q110 (BC557) and the two 1N4148 diodes should be checked too. Seen similar fault in TANDBERG-amplifiersfrom time to time. Q108 is the one near TP18, isn't it? Looks pretty worn that one too. I guess R125 just is removed for the repair of the PCB? Should not be burnt that one (47K) By the way, R28 in the first pic also seems to have been too hot. Similar faults there too?
Sooner or later you end up with TANDBERG Last edited by TANDBERGEREN; 30th January 2013 at 05:26 PM. |
#15 |
Yeah, Arcam used fibreglass PCB's... rather than the paper based board that is so common now.
The RV1/RV101 preset pots are for adjusting the bias current. As you can see it is a 1K linear preset. As long as you can get one that will fit the pin spacing, there's no need to get the exact brand. As for the damage, I have seen this before on many amps. One output device failed short, so there was full voltage on the output. The IV limiter circuitry sees this as an overload and attempts to limit the current by clamping down the base of the driver transistor. Of course, this has no effect because the output device shorted, so the resistors, transistors and diodes in the IV limiter circuit also burn. |
#16 | ||
And you're right i remove R125 to clean the PCB bettter there...i have some of it in spare...so i will put a new one as soon as i get the board repaired... The R28 it's burned too...i already measure with multimeter and it's not ok....I think both outputs circuits have the same damages...but the right one it's worst than the left. Quote:
What do you guys think about TIP3055 and TIP2955, probably any damage or not? Today i will start removing the components and clean the board...yesterday i really have no time to start this repair....keep you guys updated and thanks to all for the tips...
#17 |
You can repair the board with the Araldite and tissue as already described. If you want to be clever you can use fibre glass and resin from a car body shop.
#18 | |
I would replace the output transistors anyway as a precaution, even if they test OK. They have certainly been abused and could have shortened life as a result. |
#19 |
Ok...but there's any problem turn on the system (After repair burned components) with this ones? i mean....if they test ok but have some damage anyway...there's any risk to burn other components again beause of this?
#20 |
As I said earlier on, unless you catch all the damaged components there is a possibility that you may blow it again before you finally repair it.
TIP3055 and TIP2955 are pretty cheap and readily available. At least no-one has tried to fake them so you can buy them on E-Bay with confidence. You can also use MJ(E)3055 and MJ(E)2955 just make sure you get the plastic ones and not the T03 type. I would expect that if the outputs test OK they are probably OK. Their SOAR is such that the fuses would have blown before any real significant damage was done. HOWEVER, I might be wrong, stranger things have happened. The Power Amp is pretty simple, if you remove all the active devices for testing and replace all the electrolytics, most of the passives can be tested without removing them with the actives out of the board. Any non-electrolytic caps should be OK unless they look heat damaged. Just BEWARE of CARBONISATION of the PCB. This must be CUT OUT and repaired otherwise you will have invisible shorts. Last edited by KatieandDad; 31st January 2013 at 03:00 PM. |
| Arcam Alpha 3 | Carlosraj | Solid State | 2 | 3rd October 2011 07:23 AM |
| Arcam Alpha plus v. Alpha 5 plus v. Rotel RCD 855 | dynoPort | Digital Source | 1 | 30th March 2011 11:19 AM |
| Arcam Alpha 8R repair advice | tmr510 | Chip Amps | 1 | 12th September 2010 07:46 PM |
| Arcam Alpha 7 Repair | big jim | Solid State | 1 | 26th June 2006 02:10 PM |
| Arcam Alpha 8 | ManUtd | Digital Source | 4 | 5th April 2004 02:23 PM |
