Two Transistor push-pull AB amplifier Two Transistor push-pull AB amplifier - diyAudio
Old 29th January 2013, 01:32 PM   #1
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default Two Transistor push-pull AB amplifier
It is probably going to be difficult to beat that : a push-pull with less than two transistors being a kind of an oxymoron.
Performances are not great, but it actually works: I have tested it, with slightly different components: a 2SC1983 for Q1, and a IRF520 for M1.
I have also tried with a TIP122 darlington instead of M1 (and no R5): it also works.
Have fun!
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 29th January 2013, 01:51 PM   #2
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Very neat!
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Two Transistor push-pull AB amplifierHide this!Advertise here!
Three Transistor push-pull amp SERGIODS Solid State 5 28th January 2013 05:31 PM
Class AB Push-Pull Aurvandil Instruments and Amps 14 23rd November 2011 02:06 PM
KT88 Push Pull Amp using transistor driver stage shumgary Tubes / Valves 11 30th August 2011 09:14 AM
Class A, push pull amp using transistor space2000 Solid State 18 7th August 2008 02:53 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Copyright ©1999-2017 diyAudio
