nx-Amplifier: 100 W CFA topology Amp - Page 3 - diyAudio
Old 31st January 2013, 04:28 AM   #21
evette is offline evette  Canada
Send a message via Yahoo to evette
Sir Could you please tell me if your have any pcb,s for sale on any of your amps, Thanks Evette
Old 31st January 2013, 06:07 AM   #22
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Hello Evette - coming in the next few weeks for sx-Amp, nx-Amp, protection boards and PSU board. e-Amp will follow later in Q2
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 31st January 2013, 06:18 AM   #23
Bonsai's Avatar
Originally Posted by Samuel Jayaraj View Post
Bonsai, is the BC847 (SMD) in thermal contact with one of the Output devices or is it mounted to be in contact with the Heatsink? Due to unavailability of non-inductive power resistors and wanting to couple the nx-amp with a different protection circuit, I would like to make my own PCB (single sided, preferably). Hence, the question about thermal compensation scheme. Thanks.
Samuel, you can make the boards single sided. The sense transistor (BC847C) must be placed very close to the collector lead of one of the output devices. If its placed on the bottom side between the PCB and the heatsink (assuming you use the same construction as I do), that should work ok. I did not couple the sense transistor to the output transistor with thermal grease - you can also do that but I find it not necesary.
bonsai
Old 31st January 2013, 02:39 PM   #24
bogdan_borko's Avatar
Could you tell me what`s the bias value on the startup and after how many minutes is stabilized?
Svakog dana u svakom pogledu sve manje nazadujem.
Old 31st January 2013, 02:43 PM   #25
Thanks for the information. I'll see what method I can come up with.
Sam
Old 31st January 2013, 02:48 PM   #26
Thank You Sir,,I can,t wait. Regards Evette
Old 31st January 2013, 09:36 PM   #27
Bonsai's Avatar
Bogdan, it's set to 300mA about 1 minute after start up( 125mA per pair plus 50mA for the front end) and it goes to c 350mA after the heatsinks get hot driving a 8 ohm load.
With no music, the bias setting is very stable after switch on.
Note in this design, the drivers and the power devices are on the same Heatsinks and the drivers are fullpack TO-220. This is the same construction technique used on the e-Amp.
bonsai
Old 3rd February 2013, 05:03 AM   #28
Are the distortion figures in Your amps measured, or just simulated? I though it was measured, but You mention about simulation at page 6.
Wojtek
Old 3rd February 2013, 01:58 PM   #29
Bonsai's Avatar
Wojtek, the are the simulated results. The measurements will go up when I get a new sound card or access to an AP again.
bonsai
Old 12th May 2013, 04:00 PM   #30
fab is offline fab  Canada
fab's Avatar
Hi Bonsai
Any update on the availability of the NX amp pcb or board?
Fab
F/S Transcendent Sound CFA amp. doorman Swap Meet 4 5th April 2012 12:09 AM
Crossfire amp help please cfa-602 joesch1999 Car Audio 111 26th April 2011 02:56 AM
crossfire cfa-602, car audio amp problem tuneman Car Audio 29 23rd September 2010 05:08 AM
crossfire cfa-602, car audio amp problem tuneman Solid State 1 11th September 2010 01:51 PM
Mirand A1 CFA-Amp (Pictures) welcome comments ! pixworld Solid State 23 11th January 2005 11:22 AM
Copyright 1999-2017 diyAudio
