Can you heatsink a transistor without a exposed collector?
Old 26th January 2013, 09:51 PM   #1
Fusion916 is offline Fusion916  United States
Default Can you heatsink a transistor without a exposed collector?
Some TO126's have exposed collectors and some dont. Do heatsinks not work without an exposed collector? Pic attached for reference.
Old 26th January 2013, 09:54 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Good question. I hope someone can give us an answer.
Frank
Old 26th January 2013, 09:56 PM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The insulated collector type of transistor have similar characteristics for heat dissipation to exposed types. I prefer the insulated type as they are easier to fix to the metalwork and just need an aluminum oxide disc or plate to ensure maximum contact rather than the mica washer and heat sink compound that is required for the exposed type.
Old 26th January 2013, 09:58 PM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
As the exposed transistors have aluminium pads and none exposed plastic pads then you will get better heat transfer with the aluminium pads.
This can be a nuisance as then you need insulating washers which restrict slightly heat transfer.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 26th January 2013, 10:05 PM   #5
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Yes, but the junction-to-air resistance is higher. The insulated types therefore require a better heatsink or lower circuit dissipation for equal thermal characteristics. As example, I'm working with an LM1876 currently; seems the exposed tab is 1C/W versus the isolated tab at 2C/W.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 26th January 2013, 10:09 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
just remember the nasty greasy stuff
Old 26th January 2013, 10:11 PM   #7
Andrew Eckhardt is offline Andrew Eckhardt  United States
Wayell I think the fully encapsulated devices are generally designed to be mounted to a heatsink, because if you don't mount them to a sink, it wouldn't matter if it had an electrically conductive bottom or not, right? The whole idea is to save hardware and assembly cost.
What sofaspud said.
What I don't understand is why they have to make the epoxy so darned thick!
Old 26th January 2013, 10:23 PM   #8
could be because the heat is transferred by the epoxy, and not through it, and the mass is better ?
Old 26th January 2013, 10:37 PM   #9
No doubt the larger, all black surface has lower junction to air resistance, but I don't think it would be enough of a difference for me. If it has to lose a lot of power I'll put a sink on it.
I've actually ground down full encapsulated BD139/140 when I didn't have any with exposed metal tabs. That stuff is about .020" thick on the back of that case type.
Old 26th January 2013, 10:44 PM   #10
sofaspud's Avatar
As an aside, I have some TO-92 parts that have small P-shaped heatsinks epoxied on, with the part number printed on the sink. Can't recall the part numbers.
Can you heatsink a transistor without a exposed collector?Hide this!Advertise here!
Moving the Multiplier to the heatsink, or To3, or Collector lead AndrewT Solid State 6 12th October 2012 01:13 PM
transistor mounting technique ? Heatsink guitar89 Solid State 4 17th September 2011 01:26 PM
tda2030a heatsink with transistor output Goat Chip Amps 3 31st January 2008 09:32 AM
transistor placement on a heatsink Mattyo5 Solid State 23 5th May 2003 10:25 AM
Help - Mounting transistor to heatsink vsr123 Pass Labs 10 17th April 2003 12:43 PM
Copyright ©1999-2017 diyAudio
