Can you heatsink a transistor without a exposed collector?
Old 26th January 2013, 11:27 PM   #11
Andrew Eckhardt is offline Andrew Eckhardt  United States
Make that .030"
Old 27th January 2013, 12:12 AM   #12
CBS240 is offline CBS240  United States
CBS240's Avatar
The TO-126 with the metal backing are generally intended for medium power amplifiers and the ones without are generally intended for small signal or driver applications. The epoxy does conduct heat quite well but still has a higher Rth than the metal tab. The larger package allows for larger surface area and thus faster heat transfer than a TO-92 or TO-92(L). Another option is TO-237, or TO-92 with the collector of the die mounted to a small metal tab that sticks out of the top of the package.
All the trouble I've ever been in started out as fun......
Old 27th January 2013, 12:13 AM   #13
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Raw metal is *always* better than epoxy or any other plastic, even if you have to use greased mica or silpads.
Now, if you don't push the chip to the limit, plastic is acceptable and sure saves on mounting time and complexity.
Specially in automated or non skilled labor assembly.
Old 27th January 2013, 07:59 AM   #14
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Yes, you can heatsink them.
If not they would not manufacture because they are not retarded.
Not that good alike exposed metal, but you have a reasonable heat transference.
People is not stupid, no one born stupid...if they did that way, is because was tested that way, and passed their test and heatsinking was obviously considered and studied... they do not want to fail or to close their business.
Carlos
Can you heatsink a transistor without a exposed collector?Hide this!Advertise here!
Moving the Multiplier to the heatsink, or To3, or Collector lead AndrewT Solid State 6 12th October 2012 01:13 PM
transistor mounting technique ? Heatsink guitar89 Solid State 4 17th September 2011 01:26 PM
tda2030a heatsink with transistor output Goat Chip Amps 3 31st January 2008 09:32 AM
transistor placement on a heatsink Mattyo5 Solid State 23 5th May 2003 10:25 AM
Help - Mounting transistor to heatsink vsr123 Pass Labs 10 17th April 2003 12:43 PM
