How can you tell when you pushed a heatsink far enough? - Page 4 - diyAudio
Old 27th January 2013, 06:22 PM   #31
Originally Posted by EUVL View Post
> 60 hot heatsink is a sure way to degrade lifetime for ALL components in an Amp.
> Regardless wich class.
That I do not agree, and I have explained that in detail in the article.
Above all if you just look at heat sink temperature, and ignore the thermal path all the way to the semiconductor substrate, you may well come to the wrong conclusions.
It is in the end the junction temperature that is of critical importance, and the Toshiba reliability handbook has illustrated this clearly and scientifically.
I do agree that lower operating temperatures is always beneficial.
But the benefits have diminishing returns at some point.
So my personal design guideline is still <=100C junction temperature.
And this is much more meaningful than defining heat sink temperature.
You can start discussing where the heat sink temperature should be measured ....
But that is only my personal opinion,
Patrick
Wich very often ends up with keeping the heatsink temp lower than 60'C
Sooner or later you end up with TANDBERG
Old 27th January 2013, 07:14 PM   #32
diyAudio Member RIP
Originally Posted by counter culture View Post
A class A amp runs cooler when there is music playing.
Anybody else?
No it doesn't in reality in any meaningful way.
The dynamics of music and the fact most people don't listen at clipping
levels, usually -6dB to -10dB below that should be your normal level if
your amplifier is wisely chosen to match your system, means the drop
of dissipation is very low, and is hardly what one would call "cooler".
There is more misinformation in your statement than the real fact.
Which is course is true. If you have a class A amplifier you will never
notice. It will never appear to run cooler unless you put full power
continuous sine waves through it, which are no fun to listen to.
(Or ply it with one of those hideous no dynamic range CD's at
full power, but then what would be the point of a class A amp ?)
rgds, sreten.
a 2 yr old pushed in my friend's FF85K fishski13 Full Range 25 12th June 2010 07:37 PM
How far can a pair of SAP15 being pushed into a 4 ohm??? Leolabs Solid State 5 16th January 2007 04:42 PM
Help me please 12 inch pushed in centre dodgy99uk Multi-Way 7 16th February 2004 10:54 PM
Pushed In Cones Bider Multi-Way 11 27th January 2004 06:30 AM
Help: Soft dome tweeter pushed in Al Garay Multi-Way 46 8th October 2003 06:45 PM
Copyright 1999-2017 diyAudio
