As you know Complementary Feedback Pair is like a SUPERTRANSISTOR
have a big current gain therefore ideal for super-buffer (GV = 1) for transformer amp |
#2 |
How is distortion figures compared to the simple triple stage emitter follower PP biased into class A without feedback? And what about Thermal stability? Regards Flemming |
#3 |
the cell CFP has a total internal feedback
I've never used a simulator to calculate the distortion ![]() for the thermal stability can add a bias active in parallel to the trimmer 1K |
#4 |
Your enthusiasm is admirable. Your originality dismal. To be brutally honest a generally too simple attitude. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 |
Oh, don't listen to him. He's just being a poop.
Better to start simple and add complexity as you come to understand it than to strip off complexity you don't understand to make it simple! Cheers, Jeff Maybe you should throw it into a simulator. |
#6 |
of course
#7 |
#8 |
If you think I'm being a poop fair enough. If you think mains toroids are designed for audio, think again. rgds, sreten.
#9 |
I did some sims with this buffer and found it to be prone to oscillation and thermal runaway. Couldnt find a way to fix these issues without making it rather more complicated and even then it was a bit dicey. Back to the drawing board I would say.
#10 |
There are two strategies for the thermal drift
promote the effectiveness of bias (eg darlington) or raise the value of the resistors output for the oscillation mate better complementary pairs --> (same hFE as 2SA1186 & C) then you add capacity on driver base if need |
| CFP Buffer | whitesnake | Solid State | 6 | 17th November 2011 07:09 PM |
| CLASS A diamond CFP | Stee | Solid State | 2 | 16th May 2011 05:46 PM |
| Diamond Buffer - Super Buffer | peranders | Solid State | 34 | 16th May 2010 01:46 PM |
| CFP diamond buffer output stage with vertical FETs, thermally stable? | Russ White | Solid State | 5 | 1st January 2008 04:16 AM |
| Diamond buffers w. CFP outputs | Christer | Solid State | 39 | 26th January 2004 11:08 PM |
