Simple DIY Amp
Simple DIY Amp
Old 25th January 2013, 05:55 PM   #11
routhun is offline routhun  United States
Hi JMFahey,
Sorry my mistake, its HAL OPB not HALOpB. Anyway here is the link to it.
HAL OPB amplifier
Thanks,
routhun
Old 25th January 2013, 11:52 PM   #12
CraigP is offline CraigP  United States
Originally Posted by Fast Eddie D View Post
Yeah Craig, that's a terrible circuit for audio. It might be appropriate for a DC servo buffer.
Try an LM1875 chip. It's simple and you can build a circuit with a bare minimum of components. You can experiment with tweaking it too without getting too deep. You can use single or dual supply. A google search will yield hundreds of circuits. You might be surprised with the results.
Thanks for the info. Can anyone assist with understanding the data sheets for some of these amps? Based on the data sheet from my sound card what input sensitivity should the amp have? I see values like 300mv @ 150k ohm, 100mv @ 20k ohm and 75mv @ 20k ohm.
Any tips would be great! Lots of circuits to choose from. I just want to pick the correct one.
Thanks all!
Old 26th January 2013, 12:24 AM   #13
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Just build the cicuit suggested in the chip amp datasheet (or buy a kit) and use a volume control in its input, so you set it where you like it best.
Any value from 2x10K to 2x100K will do.
Audio or Logarithmic taper (curve) is best but if unavailable, a Linear curve will do.
Anyway you will adjust it once to some useful level and then control volume from your Soundcard.
Simple DIY AmpHide this!Advertise here!
Simple DIY Stereo Tube Amp with around 20W GentryBa Tubes / Valves 6 4th June 2012 06:46 PM
Simple & nice DIY proposal (FX120) martinsson Full Range 13 11th July 2011 10:12 AM
Simple & Low Distortion DIY PreAmp circuitscc Solid State 10 2nd May 2011 01:45 AM
Simple AMP DIY 98nassin Car Audio 6 23rd October 2007 10:10 PM
looking for simple discrete 100W DIY amp halusha Solid State 27 8th December 2006 10:30 PM
