Thermal Stability of Lateral FET Driven Bipolar Follower.
Old 23rd January 2013, 03:59 PM   #1
Andrew Eckhardt is offline Andrew Eckhardt  United States
Default Thermal Stability of Lateral FET Driven Bipolar Follower.
Does anyone have an off-hand idea how far off from stable this circuit would be? The actual application will probably use more like ten pairs of bipolar outputs for a 2.66 ohm nominal load with 65 volt rails. With only 15mA emitter current (basically class B), I wonder if it would run away if it got hot..
Old 23rd January 2013, 04:23 PM   #2
Mooly's Avatar
My instincts say not very stable because you would need around what ? 2 volts or less across the 47 ohm which is 40 milliamps or less. The FET's wouldn't hold that steady enough to be used for biasing... I don't think so anyway. The bias would be prone to wander quite a bit.
No proof, just a feeling
Old 23rd January 2013, 05:12 PM   #3
Bensen is offline Bensen  Belgium
Bensen's Avatar
I have the same opinion as Mooly.
I would change the R100 to a vbe multiplier.
See for example the Classé amps, these are proven designs.
Greetz
File Type: pdf Classe CAM-350-TM Jfet in fet driver bjt out.pdf (873.6 KB, 100 views)
Old 23rd January 2013, 05:17 PM   #4
Great help.Thanks guys..
Old 23rd January 2013, 06:49 PM   #5
east electronics is offline east electronics  Greece
east electronics's Avatar
you may also wana take a look at Zeck amplifier schematics ...Long time ago but they have been doing something similar i think
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd January 2013, 11:15 PM   #6
AKSA is offline AKSA  Australia
The bias voltage for maybe 100mA quiescent might find there is almost 2.4 volts bias between the lat fets gates. You have the lat fets biased above 27mA, but this is a bit low and this would need changing the 47R to 12R to deliver around 100mA. At this higher lat fet bias, you are around zero tempco, but negative tempco at 400mA and not very efficient. The compensation would be quite severe at the output quiescent, and they would probably might into thermal overload if you only use a resistor to set the bias voltage.
Yes, a Vbe multiplier is a good idea, using a single bipolar like a BD139. Collector to base is 1K5 and base to emitter around 330+200R trimpot in series for adjustment.
Hugh
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 24th January 2013, 02:03 AM   #7
Thanks Hugh. That about dials it in. I can see that fiddling around without the Vbe multiplier is not going to go..
Old 24th January 2013, 09:34 AM   #8
effebi is offline effebi  Italy
effebi's Avatar
Just a guess , but isn't .2 ohm a little small for ensure proper Ic balancing of 10 pairs? I would go for 0.47 at least. I have a similar design (10 pairs To3) on 2 Ohm that works happily with 1 Ohm emitter resistors.
Old 24th January 2013, 10:09 AM   #9
effebi's Avatar
In any case, if you are going with a long heat sink and forced ventilation place your bias spreader on the output side of the air flow. That side is going to be hotter and where your transistors will most probably fail if ever.
Thermal Stability of Lateral FET Driven Bipolar Follower.Hide this!Advertise here!
Stereo image stability with lateral movement vs speaker seperation DBMandrake Everything Else 13 9th February 2012 11:31 AM
Thermal compensation for BJT drivers with Lateral FET output Neutrality Solid State 5 14th October 2011 07:21 PM
thermal stability of parallel FETs zhoufang Solid State 6 26th September 2009 01:29 AM
Design for thermal stability? Bricolo Solid State 0 2nd November 2006 08:26 AM
FET+Bipolar follower biasing (To mix, or not to mix?) Wavebourn Pass Labs 6 27th September 2006 12:22 AM
Copyright ©1999-2017 diyAudio
