Dear Friends,
I am trying to fix an old P35 amp. The "radio", "CD" and "Tape" inputs are working but the "Disc" input is totally dead (no sound). There was a burnt transistor near the edge of the preamp board connected to a 100ohm resistor. Only the last digit (6) is visible, so I guess it has to be a BC546 like the other transistors on the preamp board, but still no difference. There are two TL072 eight pin ICs on the board, when I check for bipolar voltages on the pin 4 and pin 8, there are no voltages at all. Even the transistors have no voltages. I guess the voltages to the preamp board are coming from the power amp board thru the thick connecting cable. All the transistor, caps and resistors seem OK. I do not have a schematic. Pls can someone advice what could be the problem. Thank you Carlos Rajoo |
#2 |
You have confirmed the rails appear to be missing (no voltage on pins 4 and 8 of the opamps).
The burnt resistor suggests something has failed but without seeing a circuit its impossible to say what. It should be an easy fix but without seeing one, or its circuit... its anyones guess.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Cambridge audio P35 schematic wanted | sakis | Solid State | 19 | 24th November 2010 04:00 AM |
| Beard P35 and Tubes Replacement | greytear | Tubes / Valves | 4 | 30th September 2010 08:40 PM |
| Cambridge Audio 640C No audio output PLEASE HELP! | Kajman | Digital Source | 3 | 10th December 2007 09:45 AM |
| Beard P35 | Jules | Tubes / Valves | 0 | 3rd December 2007 02:03 PM |
| Need Cambridge P35 Integrated Schematic | Andy_A | Solid State | 3 | 27th September 2007 01:44 AM |
