Clarification on ClassA linearity - diyAudio
Old 22nd January 2013, 07:18 PM   #1
alvise is offline alvise  Italy
Default Clarification on ClassA linearity
Dear forum's people, I just registered in the forum and I've already a question for the experts
I've read the theory of the class A amplifiers (let's consider the configuration with 2 base voltage divider, a collector resistance and a emitter resistance); in particular I've read that a very good linearity for this topology is guaranteed when the signal excursion at the base terminal is much lower than 26mV (because of the non linear dependency of the current of the base on the base voltage - the diode I/V curve). When more class A stages are cascaded, of course this criterion is not honored anymore: in fact the output of the first stage is largely greater than 26 mV. So the question is: when I see at least 2 class A cascaded stages AC coupled (topology needed to obtain a large voltage gain) I know that they introduce some amount of distorsion. Then, why the class A amplifiers are considered by many people (let's do not take into account the power efficiency issue) the best configuration in term of sound quality ? Are the Lin topology, for example, far worse than cascaded class A stages ?
many thanks
Old 22nd January 2013, 08:15 PM   #2
Shortform answer.
A class A stage, never mind if it is in a preamp og in a power amp, is biased so the transistors are in the most linear region for transfering the signal input on the base of the transistor to the collector/emitter.
There is no particular signal level for the stage to obtain a linear transition but the 0,5 to 1,5V Base Emitter voltage needed for the transistor to "open".
A true Class A stage never have a signal level allowing the voltage between Base and Emitter to enter the non-linear transition area.
This is what makes the Class A stages more "musical" than Class B or more presise A/B where one of the output transistors is allowed to be completely turned off during the signal trace on the output. This introduces a possibility for non-linearity, best known as Crossover Distortion.
However a good Class A/B stage will have a bias set in a area where this represents no or little problem. Hence the name: A/B A bit Class a a bit Class B
But still: Class A/B works in class B most of the time. There is only when the signal-level is near 0V the stage actually is working as a Class A.
This level can possibly be 26mV, but also a bit away from this.
All depends on how high the bias actually is set.
As for the sonic quality, I have heard A/B-amplifiers with as good sonic quality as even very good engineered Class A-amplifiers. In blind tests that is.
When performing a "open" test there is always some who can hear the crossover, the shut off of the output device not working at any time. I can't.
Wether Linn topology is superior to cascaded Class A i will leave to others to write about. I haven't really investigated that.
Sooner or later you end up with TANDBERG
Old 22nd January 2013, 08:16 PM   #3
effebi is offline effebi  Italy
effebi's Avatar
Benvenuto/a Alvise!
About your question, I believe most than all is a matter of taste. You can make an extremely good od bad amplifier either in class A or class B.
The non linearity of the base char. can be solved with feedback.
One of the main problems that you have to fight with a class B is crossover distortion, that is not present in class A. However there are many circuits to avoid that, or to render it unnoticeable. And at the end, again feedback takes care of the rest.
Old 22nd January 2013, 08:23 PM   #4
DF96 is offline DF96  England
All BJT amplifiers need lots of feedback to improve linearity and to keep base-emitter signal voltages sufficiently small. The feedback will normally be some mixture of local and global feedback.
Old 22nd January 2013, 08:38 PM   #5
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Hi all,
Its a fair question, the Original Post. ... "How to determine the optimum bias for a single transistor stage, with Re (emitter resistor), Rc (collector), and input-to-Rb1-to-base, and base-to-Rb2-to-ground?"
The answer so far "well, it depends on the voltages and transistor, and desired input impedance" are all correct.
Hfe (small signal current gain) in a bipolar transistor varies from around 75 to over 500 for modern transistors. The "higher the better" does not hold - often such high Hfe transistors are more noisy, all in all. Say though a very average 200.
The first stage no matter what should be very light in gain. Its job is to amplify the signal a bit, but preserve the high-impedance input characteristic (if that's the design goal). Working with a first-stage gain of 10 dB (3.1x, voltage-to-voltage), and a nominal operating current of 10 milliamps (usually pretty standard for small-signal ends), then we need the output to be 3.1V if the input is 1V. Taking 2/3 of the supply voltage as the operating point of the collector (good rule of thumb), then the voltage drop of Rc is 1/3V divided by 10 ma. Now you have Rc.
Likewise Re is determined easily by "setting" it to a few volts - 2 to 5 is just fine. Whatever that setting is (that you make, and I'd choose 3V) then again, 3V divided by 10 ma is the resistor. Bypass cap? Sure... but it decreases linearity.
OK, next is to set quiescent (no signal) base bias current. Easy! 10ma / 200 Hfe = 50 microamps! Now we're swinging... The base can be abstracted as Ve (emitter voltage) + 0.7v, and if there were just a resistor from V+ to base for bias, it would be (V+ minus (0.7 + Ve)) / 50 microamp. As any good transistor design text will tell you, this isn't very good in practice because of the variability of transistors. It is much better to give them a "synthetic bias supply" using a pair of resistors from V+ to GND, which behaves like a power-supply having perhaps a +2V over Vb divided voltage point. At that point, figuring out the necessary series resistance from base to input jack to provide the required input impedance matching ... is all that's left.
GoatGuy
Old 22nd January 2013, 08:50 PM   #6
Old 22nd January 2013, 08:53 PM   #7
diyAudio Member RIP
many thanks
Nothing in the above makes much sense to me, so its impossible
to sensibly discuss class A in any real way in the above terminology.
The Lin topology is for a complete power amplifier, has its own
history, and not much to do with any issues related to class A.
I've no idea where you have got the 26mV idea from,
but whatever it is you have misunderstood it, AFAICT.
rgds, sreten.
26mV is related to the variation of Vbe with temperature.
Old 22nd January 2013, 09:09 PM   #8
I assume the OP has read that if you feed a BJT an XmV peak signal you get X% 2nd harmonic distortion, so he is puzzled how amplifiers can handle larger signals. I also assume he has just seen the classic textbook common-emitter stage, which almost never appears in real circuits since about 1965.
Old 22nd January 2013, 09:24 PM   #9
diyAudio Member RIP
Well one things for sure so far, nothing has been clarified.
rgds, sreten,
Old 23rd January 2013, 07:21 PM   #10
You appear to misunderstand the (small) difference between most practical class A and AB amplifiers.
I have the impression you believe that they are A or AB throughout, when normally both types operate
in class A up to the output stage. Perhaps I misunderstand what you are saying also but this type of
operation is true of most linear audio amplifiers, buffers and op-amps.
They can even be identical in every respect apart from just the bias current applied to the output stage.
If you are referring to text that perhaps is confusing, please post a reference, link etc if it is available in
English, as we may be able to assist.
Ian
Linearity rsumperl Tubes / Valves 15 3rd December 2010 06:45 PM
NFB Clarification cbj591 Tubes / Valves 9 17th July 2010 02:17 PM
An attempt for clarification. Lumba Ogir Solid State 1 4th March 2009 07:46 PM
Linearity maxpou Solid State 42 8th February 2008 10:44 PM
improve the linearity E007 Solid State 1 3rd May 2004 09:23 AM
Copyright 1999-2017 diyAudio
