Using a Variac as main transformer in DIY amplifier - diyAudio
Closed Thread
Old 22nd January 2013, 06:54 AM   #1
Default Using a Variac as main transformer in DIY amplifier
I need some input on using a 5 amp/120V Variac as the main transformer in power supply for a DIY amplifier.
If it's fixed, take it apart and make it better!
Old 22nd January 2013, 07:03 AM   #2
If the variac is just a multi-tapped autotransformer, absolutely not!
Ian
Old 22nd January 2013, 07:03 AM   #3
sofaspud's Avatar
Huh? Why?? You're up to your ears in surplus Variacs?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 22nd January 2013, 07:05 AM   #4
Mooly's Avatar
Variacs provide NO isolation from the mains. DONT EVEN THINK ABOUT IT
Old 22nd January 2013, 07:05 AM   #5
An alarm in my head says fire
Old 22nd January 2013, 07:06 AM   #6
Mooly's Avatar
Thread closed
Closed Thread
Help with main transformer specs CoolJazz Power Supplies 6 9th January 2013 04:06 PM
Will I need a transformer for this DIY Amplifier? kizm0 Chip Amps 22 3rd September 2012 05:51 PM
variac variable transformer John Bessa Tubes / Valves 19 15th October 2011 12:50 AM
Variac as transformer for LM4780 GC? brietech Chip Amps 9 18th September 2007 06:19 AM
Help for SE Main Transformer baikostov Power Supplies 4 24th September 2006 08:01 AM
Copyright 1999-2017 diyAudio
