Twin Output Stage
Twin Output Stage
Old 23rd January 2013, 11:55 AM   #21
east electronics is offline east electronics  Greece
east electronics's Avatar
Osvaldo you need to do some reading about topologies and their behavior ThE cfp or sziklai topology doesnt follow the rules that apply in a classic amplifier .
The topology you have rounded is called quasi complementary and originates from the times that was impossible to produce same NPN and PNP transistors to produce a push pull amplifier .
In a quasi complementary the NPN transistor imitates the behavior of a PNP since its wired ...upside down Other than that the topology and the behavior of the output schema has a very different principal of operation and handling than what Stee has posted in the first place .
Kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd January 2013, 12:05 PM   #22
wahab is offline wahab  Algeria
Well , in a quasi complementary output stage using NPN power devices
the bottom half of the output stage use a coumpound/sziklai pair.
Old 23rd January 2013, 12:54 PM   #23
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Originally Posted by sakis View Post
Osvaldo you need to do some reading about topologies and their behavior ThE cfp or sziklai topology doesnt follow the rules that apply in a classic amplifier.
Nah, I strongly hate BJT´s Tubes or FET's, BJT's are what they are: a fortunate laboratory accident.
In all cases, independently the name of the stage, it also continues to having the behavior than a bigger transistor, of the polarity of the first. The quasi complementary is the full output stage, but the lower (in the schematics I posted) equivalent PNP implemented with both a small PNP with a bigger NPN continues to be a classic connection between transistors, once again, I don't care who discover it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 23rd January 2013, 01:03 PM   #24
you may hate BJT as much as you like , by the way this on its own makes your opinion not valid .
A valid opinion is the one's that constructed and listen a few topologies of BJT decide what they like and what not and move ahead .
You are too far away to sent one of my P3A amplifiers over for you to listen ...I presume that after that you will have a far more complete opinion .
Kind regards
sakis
Old 23rd January 2013, 01:11 PM   #25
Appears the you don't understand me and I don't you. It is a useless discussion. I only will say this topology is classic, and I saw it in a 70's circuits.
Good by.
Old 23rd January 2013, 01:28 PM   #26
no consumer product is ever constructed like that only one Italian amplifier the alchemist forsetti
yes of course if you think that EFP stages , CFP stages , and quasi complementary are of the same classic topology we have absolutely nothing more to talk about You need to do your homework to understand what has every topology to offer and get back to the conversation with something to talk about ore something more useful.
Old 23rd January 2013, 03:32 PM   #27
Stee is offline Stee  Italy
Stee's Avatar
Default A DOUBLE PAIR OF CFP
I found the pattern of Forsetti
it seems to me excellent
but now I'm thinking that only the step-up transformer can give me the sound I'm looking for
In fact, I'm testing an amplifier completely complementary set to unity gain
on input I connected a small power transformer - works fine
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 23rd January 2013, 04:07 PM   #28
look Stee
BD 249-250 tip 31-32 old school slow devices and miller caps all over the place ... Even though designer is talking about a hell of a kick and drive ability still i wonder about the sonic signature
Old 23rd January 2013, 07:13 PM   #29
Stee's Avatar
Default analysis scheme
old is still an attractive option because the gain is set at 35 times
the parallel of cells CFP is stabilized with two capacitors and resistor 033 ohm
I do NOT like absolutely Bootstrap Capacitor
? TIP32C should certainly be replaced with type 4A Ic Motorola MJE253
(or 2SJ313 MOSFET)
by recent experiments show that the amps work well when they have no G
I'm thinking of the VAS with transformer in these days Test yourself also: D
Old 23rd January 2013, 08:47 PM   #30
Stee's Avatar
Default FOUR CELLS
Upgrade of Tapiro AMP
Twin Output StageHide this!Advertise here!
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Turn on pre driver stage first or output stage first?? Leolabs Solid State 1 6th December 2011 11:28 AM
Fender Twin Reverb channel 2 has no output ibeatsars Instruments and Amps 3 8th November 2010 05:34 AM
Ultimate twin TDA1541a DAC kit w/ tube output stage Electro3000 Swap Meet 6 14th September 2010 04:28 AM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Copyright ©1999-2017 diyAudio
