I was trying to disable the "direct" switch which bypasses the volume knob. The switch has led to trouble in the past, it will get flipped and blast my speakers with more wattage than they were ever designed for...
Anyway, I cut the cable directly next to the plug thinking that it would disable it... It didn't.. In the pictures it looks like a plug but it actually is not, which is why i had to cut it. There is plenty of room for me to re solder it. But is there anyway for me to disable it? ![]() The "direct" Switch is all the way to the left. |
#2 |
#3 |
Banned
The bypass switch simply shorts the portion of the resistor on the wiper arm gliding over the surface. Thus 'direct' I suppose? ![]() And then again, I could be wrong? Good luck! ~~~~~~~~~~ The less you know, the more you believe. ~ Bono, Irish Musician/Social Activist/Lead Singer of U2 There's no time to stop for gas, we're already late. ~ Karin Donker No one but a fool would measure their satisfaction by what the world thinks of it. ~ Oliver Goldsmith Last edited by kad; 21st January 2013 at 04:23 AM. Reason: I forgot 'you' |
#4 |
Their does not seem to be a schematic available
| Maverick Audio TubeMagic D1 DAC | dmbaile2 | Tubes / Valves | 4 | 30th November 2012 03:49 AM |
| FS:MAVERICK AUDIO D1 TUBE MAGIC | drptpcpe | Swap Meet | 2 | 12th February 2012 01:32 AM |
| D1 dac, D1v3, Pass D1 with jFET IV | tritosine | Swap Meet | 0 | 19th May 2010 03:41 PM |
| Mesa Boogie Maverick schematic any1? | spirus | Tubes / Valves | 1 | 23rd February 2008 06:11 PM |
| Screwed up!!!! | amelecsol2000 | Car Audio | 4 | 12th June 2006 11:17 AM |
