Use of ferrite beads for PS filtering ? - diyAudio
Old 20th January 2013, 04:15 PM   #1
Default Use of ferrite beads for PS filtering ?
Guys,
I'm working on a power supply mod for my SS SUMO power amplifier (Ulysses 2).
I'd like to add a bit of filtering to quiet down rectifier diode switching noise.
Couple changes:
1. RC (10 Ohms and 0.1uF) across each rectifier diode.
2. Add LC filer in series w each power rail. Filter could consist of series cylindrical ferrite bead and 1uF quality film or ceramic capacitor to ground. Ferrite has about 10...50 ohms impedance above 500 kHz. This should clean up high frequency noise.
This should keep power supply very low impedance below 100k and clean up switching noise at higher frequencies.
BUT, I've read somewhere that ferrite's are not recommended for audio use. I do not know why.
So, any comments or suggestions?
Old 20th January 2013, 04:35 PM   #2
DF96 is offline DF96  England
The word 'ferrite' covers a wide range of ferromagnetic materials made from metal oxides, which are appropriate for a wide range of different frequency ranges and applications. Some are high Q for making transformers; some are low Q for damping RF resonances and attenuating unwanted RF. I guess for 500kHz operation you would need a high permeability ferrite, but lossy too so it attenuates and not just detunes. The ordinary small ferrite beads used for stopping parasitics tend to work at much higher frequencies. High permeability ferrites tend to be quite non-linear, and easily saturated, so I think I would be careful about getting them too close to audio currents.
In many cases the route from rectifiers into audio circuits is not conduction but induction, so ensure circuit loops are small and well separated. Good grounding also helps.
Old 20th January 2013, 05:21 PM   #3
It is low frequency cylindrical EMI core optimized for 300 kHz to 30MHz range.
LFB095051-000 made by Laird.
Plan is to slip it to over the power rail bus wire. Not sure how non linear it would be. Also, not sure about saturation point.
How would you clean up diode switching noise on high current power rails?
Old 20th January 2013, 05:40 PM   #4
DUG is offline DUG  Canada
Laird Technologies does not seem to want to provide the inductance vs current information.
I was just on their site.
I would suggest finding another manufacturer that does provide that information so that you get a part that will works in your application.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 20th January 2013, 10:28 PM   #5
jcx is online now jcx  United States
rectifier diode reverse recovery current spikes can be minimized by using better diodes, Schottky are available in pretty high range today
RC snubbers can be used with slower diodes - search the forums for snubbers - "Eva" apparently designs switching PS so is well versed in the issues of diode conduction, noise has recommendations, measurements on snubbers
low ESR, ESL electrolytics are tons better today too
which ferrite beads for mos legs? richwalters Power Supplies 4 28th June 2011 09:48 PM
Ferrite beads ON chips Dr.H Digital Source 11 17th March 2005 02:24 PM
ferrite beads till Digital Source 59 17th September 2004 01:28 PM
non intrusive ferrite beads jives11 Digital Source 2 29th April 2004 11:37 AM
Ferrite Beads Narcisse91 Parts 13 3rd January 2003 01:26 PM
Copyright 1999-2017 diyAudio
