i ve checked for a schematic but seems not possible to get .would you like to state the nature of the problem ? I have been repairing some in the past and normally it should be a walk in the park to fix .
Thanks for the reply!
The problem with is amp is that the sound becomes kind of distorted on lower sound levels.
It might be a power amp bias issue or the speaker output relay.
