Inverting headphone buffer class A
Old 18th January 2013, 03:35 PM   #1
kacernator is offline kacernator  Czech Republic
Default Inverting headphone buffer class A
I would like to develop inverting headphone buffer which will be used with inverting tube preamp. Tube preamp will have 300 to 600 ohm output impedance (not sure yet about tubes I will use) and 10mA current drive capacity.
I attach schematics of the output buffer I would like to use. In simulation (TINA), voltages and currents seems to be fine (250mA bias current). But I donīt know if I need any compensation because of negative feedback employed.
Thanks.
Old 18th January 2013, 03:46 PM   #2
jcx is offline jcx  United States
what headphones is always the 1st question - they range over orders of magnitude in Z, sensitivity - no universal headphone amp is practical even restricting to "dynamic" wire and magnet types
Old 18th January 2013, 04:17 PM   #3
I will be using headphones from 32 Ohm to 120 Ohm.
Old 18th January 2013, 04:42 PM   #4
that still leaves the possibility of having 130 dB to 83 dB sensitivity - could blast your ears with 200 mV, or hiss horribly, clip dynamic peaks at even 80 dB spl ave level - all depending on which specific headphone and the amp gain, op amp noise, I,V output capability
Old 18th January 2013, 04:58 PM   #5
Headphones will be ordinary ones with about 100dB of sensitivity.
Tube preamp will have about 20dB of gain (ECC88), which is quite a lot, but donīt know or have other lower gain tube (donīt want to use ECC82).
Do you think buffer looks good?
Old 18th January 2013, 05:31 PM   #6
Telstar is offline Telstar  Italy
FYI there is a specific forum for headphones and related amps
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 18th January 2013, 05:56 PM   #7
knutn is offline knutn  Norway
If I were you, I would remove R7 and R8.
Inverting headphone buffer class AHide this!Advertise here!
Suggestions for a very low distortion class A headphone buffer ionomolo Solid State 28 1st June 2012 12:27 PM
Discrete, Class A Lateral MosFET Headphone amp (not another follower buffer!) mnturner Headphone Systems 35 6th March 2012 07:52 PM
Low-distortion Class-A line/headphone buffer linuxguru Analog Line Level 8 13th November 2010 07:00 AM
mos/bjt buffer in class A for headphone amp sunrise Headphone Systems 7 20th October 2008 06:34 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
