Accuphase E202 problem - Page 3 - diyAudio
Old 31st January 2013, 06:52 PM   #21
According to the schematic the voltage at the base of Q8 should be 16v, meaning that 10v is missing, where i don't know as all other voltages check out.
Old 31st January 2013, 10:07 PM   #22
I think there it is a problem. The schematic I am using said 4 volts at the base. Now I looked at your schematic and it is showed 16 volts. I do not know which it is correct.
Old 31st January 2013, 10:16 PM   #23
Please accept my apologies I should used your schematic. Any way let start over. Check the voltage at the base of Q7.
Old 31st January 2013, 10:19 PM   #24
I'll check in the morning it's nearly midnight here, could you post your schematic?
Old 1st February 2013, 03:32 AM   #25
Attached is the copy of the schematic I was using. I down load it from Hifi engine site.
Accuphase e202 relay reddish75 Solid State 0 28th August 2012 04:32 PM
Accuphase e202 repair glen27 Solid State 5 2nd April 2011 06:41 PM
Unclephase...based into Accuphase E202 destroyer X Solid State 8 14th January 2011 12:58 AM
Accuphase e202 right channel quiet jj0b Solid State 6 30th December 2009 02:21 PM
accuphase e202 glen27 Solid State 9 5th April 2009 10:03 PM
Copyright 1999-2017 diyAudio
