Car Audio Amplifier
Car Audio Amplifier
Old 18th January 2013, 05:09 AM   #1
Yangoran is offline Yangoran  United States
Send a message via AIM to Yangoran Send a message via MSN to Yangoran Car Audio Amplifier
Default Car Audio Amplifier
Does anyone know of a good solution for a 12V car cigarette lighter powered amplifier? (either DIY or commercial)
An age old issue I've been trying to deal with is driving music through the aux jack on my 2008 BMW 328xi with my Galaxy Nexus which does not produce loud enough of audio; annoyingly the aux and 12V power jack on this car are located in the center compartment where there isn't a whole lot of space to put anything big. (most longer car plugs will prevent the compartment from being able to close) I tried using a bluetooth receiver from Griffin ( Amazon.com: Griffin Technology BlueTrip AUX for iPhone and Smartphones: Cell Phones & Accessories ) and it was perfect form factor-wise but it was even quieter than my phone and it also completely killed the bass so I returned that within a day.
The only product I've found so far that matches the overall objective is: 12 Volt Boostaroo Revolution® Audio Amplifier & Sound Enhancer
I've been trying to look around and see if there is anything I can either buy or DIY - any ideas?
Old 18th January 2013, 10:18 AM   #2
TANDBERGEREN is offline TANDBERGEREN  Norway
How about building one based on this cirquit?
LA47536
Sooner or later you end up with TANDBERG
Old 18th January 2013, 12:45 PM   #3
Bone is offline Bone  United Kingdom
Or one of these http://www.ebay.co.uk/itm/2-X-25-Wat...item19d73a732f or http://www.ebay.co.uk/itm/YJ-TA2020-...item2ec2360c2a
Old 18th January 2013, 05:26 PM   #4
jaycee is offline jaycee  United Kingdom
You probably dont need a power amplifier at all, just some gain on the output of your phone before you feed it into the aux input of your car's audio system.
In that case all you need is a dual opamp, which you can run quite easily off of a single 12v supply
Old 18th January 2013, 05:56 PM   #5
A circuit arrangement like this would be sufficient. Any dual opamp would do such as a 4558, tl072 or ne5532. As shown, it would provide 2x gain (6dB). For ~3x gain (10dB) change R4 to 4K7.
Old 18th January 2013, 06:19 PM   #6
Yea for a DIY solution a power amp isn't needed as you only need a bit of gain for the aux jack - my visualized solution would probably be something like the following:
Power: Isolated DC-DC dual output (+/-) converter with 12V cigarette lighter input
Amp: Something like a CMOY essentially or an Objective2 with 3.5mm input and output; Voltage Gain ~5
Old 10th February 2013, 03:09 AM   #7
Here's what I ended up making in order to power a cMoyBB off of the car's 12V cigarette lighter receptacle.
I get a nice, clean, and isolated 12V to power the cMoyBB with a voltage gain of 5 which amplifies the aux input nicely.
Old 10th February 2013, 04:51 AM   #8
Hadighorbani is offline Hadighorbani  Iran
hi friend
i need a peri amp for my input amp too
can eny one help me please ?
Car Audio AmplifierHide this!Advertise here!
Help me to understand this car audio amplifier... onemilimeter Car Audio 6 14th February 2011 05:35 AM
Cantus car audio amplifier corradolvr Car Audio 1 17th November 2007 07:29 AM
Car audio Amplifier willo Car Audio 12 26th October 2005 03:58 PM
My car audio amplifier J.Carlos Car Audio 21 12th June 2005 07:46 PM
class a car audio amplifier nolan ilwan Solid State 1 27th January 2001 01:25 AM
