Need help selecting a zener on my Onkyo M504, Scematic attached - diyAudio
Old 17th January 2013, 08:49 AM   #1
Default Need help selecting a zener on my Onkyo M504, Scematic attached
Found a dead zener in my M504. The type is a 1s2076 which is a 30 volt zener. The zener I recieved from my vender is a 1s2076A which is a 60 volt zener. Looking on the attached schematic will this affect the circuit. It seems to be a -1.1 volt circuit. Not sure. The Diode number on the schematic is D431 located in the driver stage of the amp. Thanks in advance!
Old 17th January 2013, 08:58 AM   #2
jan.didden's Avatar
Can't find it - maybe you could just post the sheet with the zener and encircle in red or something.
But in general, there WILL be consequences if you replace a 30V zener with a 60V one, unlikely it will work correctly.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 17th January 2013, 09:17 AM   #3
sofaspud's Avatar
Jason, have another look. I see D433 & D434 as 1S2076TD and D431 & D432 as 1SS133.
Some confusion there.
D431 is also shown with a normal diode symbol, whereas for example D451 is the zener symbol.
D431 is located on page 8, connected between the collector of Q431 and the base of Q435. Almost dead center of the page.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 17th January 2013, 09:18 AM   #4
It's located in quadrant C3 on page 7. This PDF is locked so I cannot annotate it.
Old 17th January 2013, 09:20 AM   #5
My bad, it's D433
Old 17th January 2013, 09:53 AM   #6
Looking at the schematic D433 doesn't appear as a Zener... The data sheet states Silicon Epitaxial Planar Diode...
Old 17th January 2013, 09:57 AM   #7
Bone is offline Bone  United Kingdom
1S2076TD is not a Zener Diode but an ordinary diode with a reverse voltage of 30v. Fitting a 1S2076A in its place which has a reverse voltage of 60 volts should not affect the operation of the circuit which is part of the overload/short circuit protection. For symmetrical operation D431 & D433 should be the same type. What worries me is what caused this diode to fail in the first place and how did you find it?
Old 17th January 2013, 10:08 AM   #8
What caused the diode to breakdown was related to a cracked circuit board. The circuit board crack due to 2 missing screws in the heat sink. Dumb me wasn't thinking when I received it, not starting it up with a Variac and a light bulb. it cooked 6 transistors, 3 resistors and 1 diode all in the driver stage. did'nt make it to the output devices. It was just the left channel. Something to note in this M504 is that all the caps checked good for ESR besides the one's labeles "Sanyo". Several had high ESR. I can recall, Sanyo wasn't real quality back in the early 80's.
Onkyo M504 Transistor Mica Insulators. jasoneyes01 Solid State 2 14th January 2013 12:59 AM
Onkyo M504 Opamp upgrade jasoneyes01 Solid State 3 9th January 2013 09:27 PM
Behringer BX3000t Scematic or info discodavet Instruments and Amps 4 10th July 2012 07:13 AM
Pre amp scematic...help recks Solid State 16 31st March 2012 09:24 PM
kicker DX700 scematic/help AKHeathen Car Audio 2 9th March 2012 06:58 AM
Copyright 1999-2017 diyAudio
