Old 16th January 2013, 12:39 PM   #11
djk is offline djk
djk's Avatar
The correct device for that vintage was the MJ15024/25, earlier they used the 2N3773/6609.
Candidates for the Darwin Award should not read this author.
Old 17th January 2013, 02:28 AM   #12
jkuetemann's Avatar
Thanks for that.
I actually had some of the MJ15024/MJ15025 and even more of the MJ15003/MJ15004 already on hand. I couldn't resist, so I dropped in a set of the MJ15003/MJ15004 just to see if the thing would power up. Seemed to come up just fine (via a bulb limiter of course). Bias on both sets of TP adjusted and seemed pretty even, there was even lower DC offset than the original good channel (5mV new side, 13mV original side).
Anyone know what the bias value is supposed to be for this vintage 3B (Bryston Spec)? I measured the all original channel and it was about 6mV / 25mA but that seems a little low to me. Perhaps it isn't considering what this amp was built to do.
Seems to be accepted that the best performance comes when the is about 26mV across the emitter resistors. This would be a little over 100mA per device. Quiescent dissipation would be close to 6W per transistor, 24W per side. That seems a little high to me. If no one knows I'll see how stable it is at about 50mA per device, 12mV at the test points.
Suggestions welcome.
---Jason Kuetemann---
The greatest trick the Devil ever pulled was convincing the world he didn't exist; and like that, he's gone.
Old 17th January 2013, 03:09 AM   #13
jkuetemann's Avatar
As an aside, considering the pairs I have on hand, how much difference is it likely to make which one is used? The amp operates on +/-55V rails.
MJ15003/MJ15004
140V
20A
250W
SOA@50V=5A
fT=2MHz
Cob=1000pF
hFE=25-150
MJ15024/MJ15025
250V
15A
250W
SOA@50V=5A
fT=4MHz
Cob=500pF
hFE=15-60
Both have the same junction to case thermal resistance and derating factor.
I'm wondering if the possible higher hFE might be worth the trade off in speed? Thoughts...
Old 17th January 2013, 05:11 AM   #14
My own personal hunch would be to use the highest reliability choice, especially if these are the original 3B / 4B type units from the 1970's+.
Bryston built these amps to be rugged low-failure units for professional applications. They were initially surprised to learn that people were buying them for HiFi sound quality purposes. They did not really make design choices for sound quality specifically until the next series, once they realized a market existed outside their original intended one.
As far as my own personal opinion and experiences with listening to (not repairing, which I've never attempted) the early Bryston amps, for SQ purposes I would rank them:
Best: 2B
Next Best: 4B
The 2B and 4B are reasonably close to each other; if you need the power the 4B is acceptable over the 2B.
Finally (and noticeable step down): 3B
The subsequent series amps all sound better, But note that the 2B was not always improved in step, yet held it's own.
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
Old 17th January 2013, 06:11 AM   #15
djk is offline djk
djk's Avatar
"I'm wondering if the possible higher hFE might be worth the trade off in speed? Thoughts... "
The MJ15024/25 have higher gain at 5A than the MJ15003/04 do.
Old 17th January 2013, 12:01 PM   #16
jkuetemann's Avatar
In looking at the graphs they actually look pretty close to me (ON Semi data sheets) at the 5A mark with hFE=40ish for each device type. I picked the MJ15003/MJ15004 because I had twice as many of them, so in the event they ended up being sacrificial I wasn't out of my MJ15024/MJ15025 pairs.
The outputs and drivers are in sockets, so I can actually try both.
Old 17th January 2013, 03:55 PM   #17
djk is offline djk
djk's Avatar
Close enough for rock-and-roll (or horseshoes), save the MJ15024/25 for high-voltage use.
Old 20th January 2013, 06:36 PM   #18
jkuetemann's Avatar
And Rock-n'-Roll it does!
I actually ended up fitting a second set of the MJ15003/MJ15004 into the good original channel too. Reason was the bias setting was more even on the new side than the original and I wanted to see if that was just luck or not. Once satisfied, off the limiter it came and time for bias set-up. Gave it a good long time to stabilize and got the bias set up to the specification graciously provided by Bryston, being 10mV BTW. The bias was actually more evenly split between the devices than with the original outputs, go figure. So, there goes the idea of device matching / selection?
Played it for some time into some crappy speakers to give it a chance to operate into a load and convince me all was well. Moved it up to the living room and hooked it up to my main system. Played a variety of music and found this amp is quite pleasant with excellent extension into the bass region and smooth sounding treble.
I'm thinking I might have to place this into my system for a long term listen. Going back to back with my Yamaha AX-570 (yeah, yeah, I know, not great) it was much more pleasant. The Yamaha has much sharper treble, to the point of being comparatively fatiguing and only now shows how anemic is is down low.
Despite the thread originally being about the output transistors, I'd like to swing it towards a more holistic refurbishing. The connectors, gain controls, and switches are all quiet and in otherwise good condition so I have no worries there. The only thing really left to do is replace the few electrolytic capacitors in it, aside from the main filter caps. I'm thinking of these for the PSU. Not sure about the three (per channel) 470uF 16V aluminum electrolytic capacitors, two are just for some filtering / decoupling, the other is the DC blocking cap in the feedback path. There are also two tantalum capacitors per channel, decoupling for the zener diodes feeding the front end. Are these usually part of refurbishment too? Any value to retrofitting some nice film / mica caps for the small value units?
Only issue now is that my cabinet is only 17 1/4" wide and this is a rack mount piece at 19" wide. Be a shame to have to physically cut it, I'll have to see about alternative placement.
Old 20th January 2013, 07:48 PM   #19
djk is offline djk
djk's Avatar
Look at the tantalums. If one lead is starting to turn black it's time to replace them, they're leaking.
Replace the cap in the feedback loop with as high a quality as what you can find. I tack on a film bypass to improve HF detail, YMMV.
The main filter caps on those do go bad, hard to find the right size and value. I tack on a small electrolytic bypass to tighten up the bass, YMMV.
With the bypass caps installed it sounds more like the Leach, a good thing in my experience.
Old 24th January 2013, 07:05 PM   #20
Struth is offline Struth  Canada
Hi Guys
MJ15024/25 are what the original Bryston output devices were based on. These have twice the Ft of the MJ15003/4.
Possibly of more importance is the voltage rating: 250V for the 24/25 vs 140V for the 3/4. The outputs can see the full width of the supply, which is 180V in newer versions, maybe 160V in older.
Leach amps are quite good and benefit from matched devices. Even when fitted, THD is still 10-50 times as high a Bryston properly set up.
The new amps use TO-3P case outputs instead of TO-3. You could certainly use the flat packs on the old heatsinks but the old design was predicated on the extra 25-50C capability of the all-metal case.
Have fun
Kevin O'Connor
Bryston offers a 20 year warranty and is quite reasonable and generous with parts for older units. It is always worth asking them for advice.
London Power / Power Press Publishing
www.londonpower.com
bryston 3B bigcat Solid State 3 13th January 2012 04:30 PM
Bias setting for a Bryston 3B ? legarem Solid State 2 28th February 2008 08:02 PM
Having problem with a Bryston 3B Unique Solid State 3 29th October 2007 11:14 PM
Bryston 3B-SST Reloaded Sanken Solid State 5 21st August 2004 02:16 PM
Hafler DH200 vs. Bryston 3B wrl Solid State 6 30th July 2003 07:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
