Old 14th January 2013, 04:04 AM   #1
Default Most Powerful TO3P's ever made.
I am curious to know what the most robust, highest power, fastest TO3P outputs ever made. Anybody?
Old 14th January 2013, 04:54 AM   #2
Root2 is offline Root2  United Kingdom
Root2's Avatar
PD 100W - 140W ??? which
Old 14th January 2013, 05:20 AM   #3
So far I came up with Sanken 2SA2151 200 volt 15 amp 160W
Old 14th January 2013, 05:35 AM   #4
On Semi makes audio power transistors in TO-204 with 250 watt dice. However, they aren't the fastest, and in general the biggest aren't.
There are now over 400 watt FET dice being put in a TO-220 by Fairchild, but being designed for switching would not sound very good in linear mode, and if you tried to get more than 50 watts out of it steady state, bolted straight to a nice cold sink, it would probably short.
For biggest fastest combo there probably isn't anything better than the MJL3281.
Old 14th January 2013, 06:05 AM   #5
srh is offline srh  New Zealand
Hitachi Lateral MOSFETs.
The older I get, the more simplicity appeals.
Old 14th January 2013, 06:22 AM   #6
TO3P can refer to 2 sizes, a large TO3P(L) (TO264) and TO3P(N) similar to TO247.
I guess you are looking for the highest power plastic device with a single bolt attachment and that would be in TO264.
In use, the case epoxy material limits power so that 150 deg. max is not exceeded internally, or decomposition occurs.
That means a larger chip for safer operation. Look around - On semi might be good candiates for power with MJL21193/4
but speed puts Toshiba and Fairchild ahead with 2SC5200/1943 variants. Sankens are best all round but MT200 cases
are a little bigger than any TO3P. If you mean the TO247 size, Sanken's variants in that size are streets ahead of everything.
regards
Old 14th January 2013, 10:41 AM   #7
This is the largest TO3P's power BJT I know:
http://products.semelab-tt.com/pdf/b...20MG6331-R.pdf
Unfortunately there are no SPICE model available.
Old 14th January 2013, 11:03 AM   #8
400kg is offline 400kg  Turkey
Send a message via MSN to 400kg
2sc5359
Old 14th January 2013, 11:43 AM   #9
Boscoe is offline Boscoe  United Kingdom
On semi do some 400W devices designed for audio called something like MAG6335 or something like that I can't remember
I thought about it once, but then thought again.
Old 14th January 2013, 11:54 AM   #10
Vostro is offline Vostro  Madagascar
Vostro's Avatar
TO-3P MG6331-R
http://docs-europe.electrocomponents...6b80f8a11c.pdf
TO-264 MG6333
http://docs-europe.electrocomponents...6b80f92433.pdf
Found on RS Components
There are better ones, but these are ones that are easily available to me
Which is the most powerful Class D amplifier? eem2am Instruments and Amps 10 5th September 2012 07:40 PM
Most powerful amps highpow3rpc Solid State 0 6th December 2009 12:41 PM
Powerful bass syl Solid State 13 2nd July 2007 10:29 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
simple but powerful sr2002 Chip Amps 19 1st August 2005 06:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
