Old 13th January 2013, 10:49 PM   #1
Default Onkyo M504 Transistor Mica Insulators.
I have an Onkyo M504 I'm working on. I noticed the output devices are mounted to the heatsink without mica insulators. Is this possible that it is not required on this model. I just received this not functional M504 and need some conformation before I fire it up. This unit appears to have been tampered with as it had a cracked circuit board when I received it.
Old 14th January 2013, 12:03 AM   #2
nigelwright7557's Avatar
It depends if the transistors are isolated tabs or not.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 14th January 2013, 12:59 AM   #3
As I was cleaning the heatsink, surprising there was a sliver of mica. It was delaminated. Definately need to change these out. My bad. Checking the resistance between the to3p case and heatsink revealed leakage thru the mica on some of the output devices.
Onkyo M504 Opamp upgrade jasoneyes01 Solid State 3 9th January 2013 09:27 PM
TO-3P mica insulators available lhquam Pass Labs 8 31st December 2010 02:35 AM
mica insulators aarifah Everything Else 0 20th August 2008 07:26 PM
Mica Insulators glen65 Solid State 5 22nd December 2006 07:15 PM
WANTED: mica insulators richeros Swap Meet 1 14th February 2004 09:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
