CYRUS PSX POWER UNIT
Old 13th January 2013, 10:00 PM   #1
ftpols is offline ftpols  Japan
ftpols's Avatar
Default CYRUS PSX POWER UNIT
There was a plastic shield lying loose in the PSX when I opened it. It has a white strip along one long side. I thought the white strip was adhesive but it isn't tacky. I replaced it as shown but could you or someone kindly confirm the correct location and where the white strip faces toward; e.g. towards the toroid trans, etc. Many thanks.
Old 14th January 2013, 08:35 PM   #2
TANDBERGEREN is offline TANDBERGEREN  Norway
Just locate the mains-bearing tracks at the PCB, and locate this strip centered beneath them, og towards the end of the pCB.
I would have secured it to the PCB with an adhesive device, similar to the 3M-photopads ,
as this will keep the strip in place where it belongs.
Sooner or later you end up with TANDBERG
Old 15th January 2013, 12:23 PM   #3
ftpols's Avatar
Thanks for your help TANDBERGEREN. The casing has a step at the front of where I located the insulating strip. It seems the insulating strip prevents the underside of the PCB shorting with the chassis at this point. That is the only purpose I could think of and why I located it there. (I applied contact adhesive at a couple of spots underneath the insulating strip to secure it.)
CYRUS PSX POWER UNITHide this!Advertise here!
Cyrus PSX dead gfredriks Solid State 98 4th June 2014 05:12 PM
mission cyrus 2 PSX bonjaribros Solid State 4 31st July 2008 10:28 PM
Mod Cyrus II power train for PSX? enthusiastor Solid State 20 27th June 2007 03:35 PM
Cyrus PSX-R copy dubh Solid State 3 7th February 2007 04:59 PM
