The Old Hum question - diyAudio
Old 12th January 2013, 09:53 PM   #1
Default The Old Hum question
Hi all,
i recently got a Belles 150A amp, used. i keep it running and it sounds great. just a quick question;today i noticed what sounded a lot like a ground loop hum, and moving closer it was coming from the amp. i went away and about an hour or so later noticed it was gone, back to silent. does this mean or portend anything?
thanks for any input,
Go Seahawks!!!
Scott
Old 12th January 2013, 10:10 PM   #2
nigelwright7557's Avatar
Do you mean hum from the amp or from the speakers ?
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 12th January 2013, 11:29 PM   #3
well,
it was coming from the speakers and the amp. no other symptoms. then, it just sort of went away. almost like noise from the xformer. but i'm not sure exactly what was causing the sound.
Old 12th January 2013, 11:32 PM   #4
A noisy transformer is usually a sign of a heavy load.
I would check your speaker leads for poor connections/shorts.
Old 13th January 2013, 12:33 AM   #5
DUG is offline DUG  Canada
If this happens with increased heat for output devices hook up a scope and check for oscillations...might be drawing lots of power.
Just another possibility.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 13th January 2013, 02:19 AM   #6
yeah, that was what i was thinking, but why would the load increase when i'm just listening to FM tuner at really low volumes? and then it goes back to normal. just kinda puzzling really. can relative humidity do this? it's unusually dry and cool here lately.....
hmmm, (not to be confuse with Hummmmmm)
scott
Old 14th January 2013, 04:21 AM   #7
We occasionally see threads referring to periodic low level hum coming from transformers and sometimes also audible through the speakers.
This is often put down to mains-borne noise and DC appearing on the mains due to various local loads and load sharing problems that are in
the hands of the power company. Unfortunately, you have to get some fancy measurements of your supply to be sure of that.
Some amps and particularly big transformers are sensitive to DC components in the supply, for some reason, but it does happen. If there is
no sign of deterioration in the normal power capability and sound quality of your amplifier, I would be looking there for trouble.
However, if your amplifier is old and constantly on, I would be considering some maintenance like replacement of the electrolytic capacitors
- just as a reassurance that the power supply caps, for example, aren't failing. This is not uncommon.
Ian
Old 14th January 2013, 12:42 PM   #8
Hi Ian,
thanks for the reply, very helpful. i'll look into replacing the caps here soon, i've been thinking about that since i got the amp.
Scott
Guitar Amp Hum Question Trout Instruments and Amps 9 11th August 2013 04:29 PM
B-5 hum question coils Pass Labs 12 7th March 2011 07:41 PM
Question on output hum on tube amp? andy2 Tubes / Valves 11 4th November 2006 11:04 PM
Hum Pot Question Trout Tubes / Valves 6 13th December 2005 08:44 AM
Another Zen V2 hum question, yawn... Shoog Pass Labs 9 26th December 2002 05:09 PM
Copyright 1999-2017 diyAudio
