#71 |
10% THD is barely perceptible... try it for yourself. At 5% THD, you won't even pass the blind test.
#72 |
This is BS, I clearly notice about 1dB steps if not less.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#73 |
10% THD would be 20dB down.
"This is BS, I clearly notice about 1dB steps if not less. " Depends on the circumstances. I made a stepper attenuator for an HF driver that went in 1/4dB steps. While the effect was clearly audible, no one could say if I had raised or lowered the HF by 1/4dB, though all would say that the sound had "gone out of focus" with the change.
Candidates for the Darwin Award should not read this author. Last edited by djk; 27th January 2013 at 10:45 PM. |
#74 |
Sorry but distortion meassurements compare Power, not Voltage, so 10% (distortion/noise/whatever) is 10% the power of the full signal, = -10dB.
#75 |
My HP distortion analyzer must be defective then.
Candidates for the Darwin Award should not read this author. |
#76 |
#77 | |
If the eventual failure is burn up or breakage due to excess movement is neither here nor there. The point is the tweeter died because of being fed too large a signal by the clipping amp. |
#78 |
#79 |
An analog synth, or even using an oscillator set to, say, 6KHz sinewave and then driving the amplifier to clipping , simply is NOT a realistic test signal , it can't be used as "proof" as to what a Music program , (*any* music program by the way, from Classic to Punk to Death Metal) can do when overdriving a Power Amp connected to a multiway Speaker cabinet, which is the point of this discussion.
OF COURSE, if you drive a tweeter coil with 100W RMS sinewave (clipped or not) at a frequency which passes easily through the crossover, it will burn the VC before mechanical stress breaks the wire. So what? Not what we are discussing here. |
#80 |
I have no intention to start off with a 6kHz wave.
I'd use a 100Hz sine and clip it or 50Hz or 20Hz, it doesn't really matter as long as it is well below the crossover point so that none of the original, unclipped signal would ever reach the tweeter. |
| 100w to 1000w class ab | nazirdigi | Solid State | 76 | 5th May 2013 02:06 PM |
| solid state amp warm-up time, myth or fact? | Tony | Solid State | 100 | 16th December 2012 10:19 AM |
| Why can 8W sound as loud as 100W? | AudioIsFun | Tubes / Valves | 19 | 26th January 2004 03:05 PM |
