#21 | |
perhaps I was clear enough AFTER using contact cleaner, if the pot is still a problem, THEN try WD-40 I am NOT suggesting spraying WD-40 willy-nilly. IF at that point, it did soften the binder (destroy the pot), who cares...it was already a lost cause. and in 10 years I had yet to destroy a pot using WD-40, however I have noticed that I have to 'move' the pot a little slowly else the noise comes back - though it disappears when I go back to 'moving' it slowly. It is a last ditch effort. It has worked several times for me............... Last edited by KMossman; 25th January 2013 at 10:28 PM. |
#22 | |
I have had to 'correct' some amps that had problem (no blocking cap, and a poor design were the causes). |
#23 |
any presence of DC even as small as1/2 a volt on a volume control should be investigated as it's not supposed to be there.
#24 |
I agree - usually there should be no DC on a volume control, but isn't the current the major concern?
ie 0.5V at 100mA is a disaster 0.5V at 100picoAmps is curious |
#25 |
Hi gencogenco,
I am trying as well to solve a potentiometer issue like you are trying here. Did you solved it ? In the same time there might be a little off topic but I would like to know your symptom details since there are not stated in the begining post. |
| Looking for potentiometer | skidave | Parts | 1 | 24th September 2007 05:26 PM |
| Potentiometer | SergeDufour | Vendor's Bazaar | 0 | 12th December 2006 08:30 AM |
| Need some help with potentiometer. | mkapszewicz | Tubes / Valves | 6 | 29th November 2006 04:55 AM |
| PC loudspeakers potentiometer problem | michaelpage26 | Parts | 3 | 23rd April 2006 11:05 AM |
