Back to Back Polarized Electro's
Old 15th November 2003, 02:04 AM   #1
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Default Back to Back Polarized Electro's
I thought that if you wanted to make a bipolar out of two back-to-back polarized electrolytics that you connected the negs to each other, and the positives to the outside..
device > + - - + > device
However, working on a few old amps where they have the positives together, and the negs to the outside...
device > - + + - > device
Perhaps it doesn't matter. Is that the case?
Old 15th November 2003, 02:17 AM   #2
thoriated is offline thoriated  United States
To me, thinking about the workings of back to back or nonpolar 'lytics (same thing) is like thinking about how sausages are made or politicians do their thing. Whatever is supposed to happen sorta does, even though the hidden details are fairly gruesome. So connecting the pluses vs the minuses to make a nonpolar probably works equally unwell. If you want to improve the situation, try adding a low current dc bias (through a highish value series resistor) in excess of the peak value of the signal to be passed to the tied together node of the 'lytics.
Old 15th November 2003, 02:30 AM   #3
EE_Mark is offline EE_Mark  United States
Default Nonpolarized electrolytics
It doesn't matter whether the + terminals join or the - terminals join. It makes absolutely no difference whatsoever. I either case one of the caps will be reverse biased and will look lie a low impedance so the voltage will dropn across mthe capacitor that is seeing the correct polarity.
Mark
Old 15th November 2003, 02:32 AM   #4
Default I should try proofreading my massages!
It doesn't matter whether the + terminals join or the - terminals join. It makes absolutely no difference whatsoever. In either case one of the caps will be reverse biased and will look like a low impedance so the voltage will drop across the capacitor that is seeing the correct polarity.
Mark
Old 15th November 2003, 03:00 AM   #5
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Back to Back Polarized Electro's Back to Back Polarized Electro's
But since negative terminal is often connected to the can, it would be more practical to connect the negative terminals.
(just a good idea if they are close or naked...)
Arne K
Don't believe everything you think...
Old 15th November 2003, 04:55 AM   #6
jcx is offline jcx  United States
Cyril Bateman talked about al electros in his "Capacitor Sound" series in Electornics World mag last year, with a recent amp re-cap distortion measurement follow up just this month
basically he claims the thin spontaneous film on one electrode in a polar cap causes large distortion, for lowest distortion he recomends bipoalr electros which are made with full thickness oxide on both foils, further lowering V stress on the oxide by series connecting bipolar electros is his strong recomendation for lowest distortion in large value cap applications
Old 15th November 2003, 06:49 AM   #7
Default In plain English
I think what he's trying to say is I'm right. If you're really worried about it drop $5 and buy some Sanyo SG Series Os-Con caps.
http://www.bdent.com/
Mark
Old 15th November 2003, 09:07 AM   #8
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: Back to Back Polarized Electro's
HiEchoWars,
Better use bipolar electrolytics if you have to use elco's.
Old 15th November 2003, 11:03 AM   #9
EchoWars's Avatar
Naaa....not really doing anything to this amp, it runs fine...just saw the back to back electrolytics with positive sides connected wheras I've always seen the negatives connected.
Thanks for the reply guys...always learning something.
Old 15th November 2003, 04:39 PM   #10
On Hiatus
SY's Avatar
EW, we had a long thread about this a few months back which included some experimental resuts (including my clumsy attempts at scope photography). It's probably worth doing a quick search.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Back to Back Polarized Electro'sHide this!Advertise here!
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 11:10 PM
back to back isolation transformers: maxlorenz Parts 30 27th March 2006 04:15 AM
back to back coupling capacitors reddog Solid State 5 3rd January 2006 07:59 AM
Back to Back transformers to get +B of 200V ?? Shoog Tubes / Valves 5 23rd September 2005 04:58 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 06:34 AM
