Bias, not same output etc .... Pls help Bias, not same output etc .... Pls help - diyAudio
Old 9th January 2013, 10:39 PM   #1
tony Ma is offline tony Ma  United States
Default Bias, not same output etc .... Pls help
Dear All,
I have B&K St-140 that I replace the electrolytic capacitor with elma silmic.
One side (R channel total dead) so I replace with new transistor J50 and K135.
Just FYI: I measure secondary wiring is 46V x 2 and the DC input to PCB is 65V
There are 3 cable going to PCB. RED 65V, Green 0V, Black (-)65V. (I put the multimeter to DC with black tip to amp chassis)
Last night I found this thread
Amplifier Distortion, DC-Offset, and You! - AudioKarma.org Home Audio Stereo Discussion Forums
I did measure mine with no load meaning just amp itself and I set my Multimeter to DC with + to RED speaker out and - to black speaker out
When it start R = (-) 89mv and L = (-)87mv
After 20 minute R = (-)87mv and L = (-)94mv
My questions are
1. Why I got negative reading?
2. How to set bias? which Pot? there are 2 pots here (I only have Multimeter)
Can some one guide me step by step please??
tks
Old 9th January 2013, 10:42 PM   #2
pls see picture
Old 10th January 2013, 11:46 AM   #3
madtecchy is offline madtecchy  England
You mention DC offset and also Bias ?????
Old 10th January 2013, 12:49 PM   #4
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
P1 sets offset voltage.
P2 sets the bias current of the output stage.Setting P2 is dangerous for the amp if you don't know exactly what you are doing
http://6streetbridge.blogspot.fr/201...amplifier.html
Edit: +/- 65V looks high for only one pair of output devices
Old 10th January 2013, 12:51 PM   #5
I see no presets in the piccy just blank spaces.. Unless they are hiding underneath the pcb
Old 10th January 2013, 12:57 PM   #6
Can be seen on 4th pic.
Old 10th January 2013, 01:08 PM   #7
And now i see .. thankyou .. Hi ho hi ho its of to spec savers i go
Bias, not same output etc .... Pls helpHide this!Advertise here!
How does the audio output work in amplifiers?....can someone explain to me? Pls chipper Car Audio 12 17th May 2010 10:30 PM
output bias servo ErikdeBest Tubes / Valves 1 2nd October 2006 01:27 AM
dac tube output stage..pls help. tone Tubes / Valves 80 25th March 2003 06:13 PM
Copyright ©1999-2017 diyAudio
