Help ID 2 transistors - Page 2 - diyAudio
Old 9th January 2013, 07:37 PM   #11
Mooly's Avatar
2N2222's should work OK. You don't need change any components for using different transistors in this circuit. Make sure you identify the connections correctly... and if you have the choice get some more modern devices like the BCxxx devices mentioned. If your 2N2222's are metal encapsulated then that makes them less of a good choice due to possible pickup of noise and hash... which I guess in a phono stage is important.
Installing and using LTspice IV. From beginner to advanced.
Old 10th January 2013, 04:32 PM   #12
Originally Posted by brucetassin View Post
I have several 2N2222 on hand. I'm not a designer so would I need to change
any resistor values for the 2N2222's to work properly. I have a tube pre-amp, a op-am pre-amp and I want to build the transistor version just to amuse myself.
thanks all for helping.
Bruce
Send me Your address, and Ill donate some good ones for You.
Sooner or later you end up with TANDBERG
Old 10th January 2013, 05:37 PM   #13
Tandbergeren,
Your offer is most generous, thank you but that will not be necessary. If you have a better schematic of a transistor riaa pre amp I would accept that.
I am retired and need something to keep my mind active so I decided to built
the EICO pre amp. I'm just having fun.
thank
Bruce
Old 10th January 2013, 05:48 PM   #14
east electronics's Avatar
Bruce since you have as you said available time you may evaluate for us sonic difference on various capacitors or semis ..now that can be of some use ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 10th January 2013, 05:54 PM   #15
Mooly's Avatar
Tandbergeren,
thank
Bruce
Have a search for the Radford ZD22 and HD250 amps. Classic all discrete single rail design and hard to better even today sonically.
Old 26th January 2013, 01:56 PM   #16
After some suggestions, I choose the transistors as indicated on the schematic.
I am very happy with the results, highs and bass are all present. I don't know how to evaluate the sound so I have no idea what the distortion is or even the frequency range. Having said that, it sound pretty good to my old ears.
Old 26th January 2013, 02:09 PM   #17
Mooly's Avatar
Thanks for the update. Pleased to see it worked out and you like what you hear Simple discrete circuitry can often sound surprisingly good.
Please help ID output transistors in Crown D150A Fasterdamnit Solid State 4 2nd September 2012 05:59 PM
need to id these transistors PreSapian Parts 3 18th April 2012 01:38 PM
ID this for me? rntlee Tubes / Valves 8 29th February 2012 07:22 AM
Please Help ID this... Diode? jmlandry Solid State 10 3rd June 2010 04:07 AM
Please help ID this: martioz Everything Else 0 27th June 2006 05:34 AM
Copyright 1999-2017 diyAudio
