Symmetric Amp, Interesting Output Stage - diyAudio
Old 8th January 2013, 11:03 PM   #1
Hentai is offline Hentai  Japan
Default Symmetric Amp, Interesting Output Stage
Hello,
Looking back through some of my old notes, i found a schematic of a power amp i drew a while back. It was based on a 3 transistor buffer designed by John Bowers an engineer from Dynatronics. I have used this buffer back then in preamps and loved it. The components nowadays may render it obsolete but it can achieve low drift and low offset, better than darlington
Current gain of the stage formed of Q44,46,47 is Beta44*Beta46*Beta47 +Beta44*Beta46+Beta44+1.
A basic sketch of the amp is attached. I haven't played with solid state in a good time so I'm a little behind with components available today. I would like to hear from you comments about it, if it is worth pursuing and i would like help on choosing the best transistors.
I have looked on Sanken, Toshiba, On Semiconductor offer and have some ideas but would like to hear more from you.
Based on my experience with this buffer in line level applications i think it will be worth looking into using it with power applications.
Thank you.
Old 9th January 2013, 12:57 AM   #2
AKSA is offline AKSA  Australia
Hi Hentai,
This is a very interesting output stage, unique.
However, and the double phase shift is similar to the Bryston, I suspect this would create a distributed phase shift.
This might cause errors for depth of image and possible with resolution. You might know if this is right or wrong, I would be interested in your insights of the sonic qualities of this amp.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 9th January 2013, 02:21 AM   #3
Default Problematic front end
I think the front end will suffer from the usual problem of ill defined current in the VAS with this IPS, as seen in the Slone amp and similar. Have you ideas for this?
An unfamiliar buffer is fun to see. What benefits do you think it has?
Best wishes
David
Old 9th January 2013, 03:28 AM   #4
Hentai
I don't understand how this output topology can set the idle current through Q47/48.
It's a CFP but with an emitter follower added, however as shown there doesnt appear to be feedback directly to the driving transistor.
-Antonio
Old 9th January 2013, 11:53 AM   #5
Hi, thanks for replies.
I will study this and will post some sims soon.
I've looked at the Slone amp, indeed similar front end. Can you offer more details about its problem? Front end will suffer modifications i'm sure.
As far as benefits at a first glance high current gain, low offset and drift, keeping base-emitter voltage at Vbe and lower saturation voltage than darlingtons.
CFP with emitter follower, yes thats a good description. By driving transistor you mean Q45/46? if so it is just like CFP.
Old 9th January 2013, 12:25 PM   #6
jerluwoo's Avatar
Will probably have to add some low value resistors from Q43/44 collectors to the rails since they will draw all of their current through Q45/46 BE junctions and may cause them to burn out.
Old 9th January 2013, 12:52 PM   #7
Don't think it will be necessary as the current drawn by Q43/44 is very small, that's why it can connect directly to VAS stage.
Old 9th January 2013, 01:02 PM   #8
For the same reason I neither could figure out that output stage, but actually there will not be drawn too much current through there, as the Q45/46 will ensure that the Q47/48 weill be driven much earlier than the Q43/44.
All in all a near pointless topology for this output-stage, unless one solely looks at the purpose of leaving as little load to the VAS as possible.
But to obtain that, there is quite a number more efficient ways to do exactrly that.
I would really say that Q45/46 is in fact a part of the VAS.
Sooner or later you end up with TANDBERG
Old 9th January 2013, 02:21 PM   #9
Well Q45/46 output current, dont think it as part of Vas. I'm not sure what you mean by more efficient and i would like to read more about it.
Old 9th January 2013, 07:06 PM   #10
Start here Unstable VAS current in amp from Slone book
and here HEEEELLLPPP : M. Randy Slone Mirror Image Topology Construction - Troubles
Bob Cordell's book discusses this and shows an effective solution. Edmond Stuart's CMCL circuit concept also appeals to me. But I am still interested in new ideas.
Best wishes
David
Last edited by Dave Zan; 9th January 2013 at 07:15 PM. Reason: Added Cordell reference
Balun output board for symmetric DAC chips jean-paul Swap Meet 3 31st July 2012 04:13 PM
Class A amp with fully symmetric design using only NPN output transistor muddasirwaheedmalik Solid State 26 18th June 2012 06:59 PM
Interesting output stage idea keantoken Solid State 18 15th November 2006 11:41 PM
Interesting challenge:GU 50 output stage! Le Basseur Tubes / Valves 10 15th October 2004 07:04 AM
Copyright 1999-2017 diyAudio
