Analog VU meter driver
Thanks for the reply's you all,
I found an easy circuit, I've tested it and it works fine ! Circuits Online - Schakelingen - VU meter It seems to work from the line inputs.
Hallo all. I have used this circuit before on VU meters and it works fine. But now I have Sifam db meters that I want to use and this circuit adjusted on max can only drive them a third of their full scale. The resistance of the new meters are 5.5 Ohm. Any Ideas how to improve this circuit to drive them to full scale will be appreciated.
Hi Jan,
Here is the pdf of circuit I posted. I replaced the gnd plane with traces. Hope it is useful to you.
reg
Prasi
gerbers as per request by PM. I haven't tested it nor do I know anyone who has.
  • VU METER BC547wo gnd plane-led-res.zip
