solid state with output transformer
Old 8th January 2013, 10:40 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default solid state with output transformer
I have invented a method to sound the amplifier in the solid state as a valvular, so reduce to a minimum the negative feedback with a rule called 1:100
Take a simple amp
Ie without cascode in the input stage, without cascode stage voltage and with unity gain in the output stage (without Darlington)
The open-loop gain will be approximately 27dB
Set the closed-loop gain to a gain much greater 40dB
(set NFB resistor's ratio one to hundred)
This means doing the opposite of the traditional approach
You will get a sound but not distorted, but no EQ
This is because there is no longer a residual gain sufficient to correct the waveforms extensive (low frequency)
In short you are listening to the real sound of your amp
And you realize that the impedance matching the speaker load is scarce
My solution is to adopt an output transformer more powerful than that required
With very low transformation ratio (7:1)
So as not to inflict emphasis on the acoustic scene and at the same time allow the device to an internal resistance adequate
The result is excellent (tested on diagram Rotel RA-02 with toroidal transformer 230/32 +32 V 300VA)
http://www.esafono.it/Esoter%20Evoqu...0Amplifier.pdf
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 8th January 2013, 12:06 PM   #2
lcsaszar is offline lcsaszar  Hungary
I would suggest to study a high school textbook on linear systems and negative feedback. You will find a formula on the first few pages how the closed loop gain can be calculated.
Old 8th January 2013, 12:17 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Stee,
The feedback factor is the difference between open loop and closed loop gain.
If you wish to lower the feedback factor so that you can listen to the amp non-linearity better, you can just lower the open loop gain and save the cost of the xformer.
Loading T1 collector would be a convenient place.
You coulkd even put a pot there for continuous control of open loop gain and feedback factor.
jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 8th January 2013, 02:35 PM   #4
Stee's Avatar
Default closed loop gain
If you wish to lower the feedback factor so that you can listen to the amp non-linearity better because lose equalization
the attenuation factor of the feedback(and viceversa the correction factor) does not behave as you think
is difficult to set a dime with potentiometer - better to add a resistor in parallel
Old 8th January 2013, 03:49 PM   #5
wahab is offline wahab  Algeria
Congratulation for the never lacking originality.....
Old 8th January 2013, 03:55 PM   #6
Stee's Avatar
I speak about equalization because the negative feedback is a system of dynamic attenuation
This system attempts (up where he space of action) to correct the deficiency by the load current increasing the voltage
This happens on the frequencies of large amplitude that the bass
where there is no output stage is really capable (large parallel end devices es.TIP35)
Old 8th January 2013, 04:23 PM   #7
GoatGuy is offline GoatGuy  United States
Sin Bin
Redacted by author
Last edited by GoatGuy; 8th January 2013 at 04:50 PM. Reason: Being wrong... should be corrected.
Old 8th January 2013, 04:47 PM   #8
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Goat, I believe you are wrong. The anode of the led is wired to GND via a 22K resistor, and the cathode to -42V, so it really has about 20 mAcurrent in it.
Although, I canīt understand how this circuit warranties or ensures an idle output voltage less than the famous 25 milliVDC though the load, and prevents temperature drift of this output voltage. (???)
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 8th January 2013, 04:50 PM   #9
Sin Bin
I redacted my note. You are right, Osvaldo. It is early here in San Francisco CA. The "coffee isn't working" ... is true.
Old 8th January 2013, 04:52 PM   #10
Art M is offline Art M  United States
Originally Posted by GoatGuy View Post
Stee...
Ummm... hate to call it what it is, but "********", brother.
The "Quasi-zero feedback amplifier" in the original PDF cannot work. It has at least 4 design errors. One is significant enough to prevent operation of the long-tailed differential pair up front, completely.
Specifically, the resistor R8 is connected to ground, which prevents the current source Q1 from conduction, at all. The LED will never light, as there is no V+ path to it. Now... go find the other 3 errors ... they're not as significant, but just as important.
GoatGuy
Please point out the other 3 errors on this proven design.
300/500W Subwoofer Power Amplifier
solid state with output transformerHide this!Advertise here!
Solid State amp with output transformers vizion Solid State 32 19th December 2016 04:35 PM
output transformer for on solid state dual channel for THD reduction muddasirwaheedmalik Solid State 12 23rd May 2012 03:49 PM
What Solid State Amps with Output Transformer do you know of? Onvinyl Solid State 27 27th April 2010 11:41 PM
Solid State Replacement of Ribbon Transformer? tmblack Pass Labs 5 31st January 2010 05:49 PM
Transformer output solid state lumanauw Solid State 34 3rd April 2007 03:14 PM
