Matching the IRFP240 9240? how many will be wasted in ratio? - diyAudio
Old 7th January 2013, 12:59 AM   #1
Default Matching the IRFP240 9240? how many will be wasted in ratio?
I would like to build an amp using IRFP240 9240 pairs.
so usually how many will be wasted in an avg ratio where we could get a match to acceptable tolerances
1:20? or more?
the reason why is just to know how many to buy?
Old 7th January 2013, 01:09 AM   #2
nigelwright7557's Avatar
The 240 and 9240 are quite different transistors so don't match very well.
However this isn't a problem in amplifiers as feedback sorts out any differences.
I have designed a few amplifiers using 240/9240 and they sound very good.
If you want to match say the 240's then I wouldnt bother as they are likely from the same batch anyway.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 7th January 2013, 01:12 AM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Perhaps, in a push pull topology, differences between the n type and p type may not be such a bad thing - as the result is mostly 2nd harmonics ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th January 2013, 02:44 AM   #4
its for pushpull config...
are they better than conventional Toshiba mosfets? in terms of sonic qualities?
Old 7th January 2013, 02:48 AM   #5
how to match? just measure the RDS with multimeter any ckt for matching these?
Old 7th January 2013, 05:47 AM   #6
F5 output MOSFETS matched or not?
Ian
Old 7th January 2013, 06:55 AM   #7
KatieandDad's Avatar
When I was matching for sextets, I needed 4 x 6 sets. I achieved this with a batch of 50 IRFP240's.
Old 7th January 2013, 07:19 AM   #8
sajti is online now sajti  Hungary
No resistance measurement. Nelson Pass has some pictures how to match Your FETs. Try to search for that.
Sajti
Old 7th January 2013, 07:40 AM   #9
Check it: http://www.passdiy.com/pdf/matching.pdf
Sajti
Old 7th January 2013, 09:40 AM   #10
h_a sells them already matched over in the swap meet forum.
IRF540/9540 or IRFP240/9240 Ermac Solid State 19 21st May 2015 03:06 AM
Mosfet IRFP240/9240 BrianVG Solid State 70 18th May 2011 08:09 PM
300W amp, IRFP240/9240 Federmann Solid State 1 18th June 2010 01:45 PM
IRFP240/9240 amp Schematics Zero Cool Solid State 8 25th May 2009 03:38 PM
Irfp240/9240 A75 PassFan Pass Labs 4 6th July 2008 02:58 PM
Copyright ©1999-2017 diyAudio
