Quick question on capacitor charge/discharge
Old 5th January 2013, 07:00 PM   #11
pete_schumacher is offline pete_schumacher  United States
Originally Posted by bobodioulasso View Post
The big transformer inrush current is the main issue to deal with.
Soft charge is secondary.
When you say transformer inrush current, are you referring to the current it requires to build up the flux in the core? Does that require controlling current on the primary rather than the secondary?
Old 5th January 2013, 08:37 PM   #12
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Yes, primary surge is huge and will blow the fuse. (if only)
A soft start is needed in the primary. A thermistor shunted by a relay for instance.
Capacitor charging is usually not an issue except for an extravagant amount of capacitance.
Old 5th January 2013, 09:22 PM   #13
Well I suppose if you're taking care of the primary inrush, the cap charging is taken care of by default.
I guess I'm going to use a resistor/relay combo on the primary then.
Thanks!
Old 6th January 2013, 05:06 PM   #14
sbrads is offline sbrads  United Kingdom
I don't know if you can still get them but old TVs etc used to have a mains series NTC resistor that was a few tens of ohms at ambient to reduce startup surge and as it warmed up it dropped in resistance to let full power flow.
Old 6th January 2013, 05:22 PM   #15
Thermistors are still in production. I thought of using them, but they only work when cool. If an accidental power cycle takes place after the unit is warm, they don't do the job intended. Bypassing them with the relay is a possibility to let them cool after their initial surge, but it seems that a power resistor would do the same thing.
Thanks for all the suggestions guys.
Old 6th January 2013, 07:56 PM   #16
TANDBERGEREN is offline TANDBERGEREN  Norway
A good softstart (primary of the transformer) will solve your problem anyway.
And at the same time reduces the surge on the power line in to the amp.
A real win-win-situation.
Then You won't need any bypassrelay or fet on the secondary either.
Cleaner, more efficient and power when you need it where you need it.
Sooner or later you end up with TANDBERG
Quick question on capacitor charge/dischargeHide this!Advertise here!
Quick capacitor question rocco gibralter Solid State 2 10th January 2009 01:20 PM
capacitor discharge? epicfabrication Parts 1 25th September 2008 12:12 PM
Capacitor discharge thkking Car Audio 16 11th June 2005 07:26 PM
capacitor charge question Thomas001 Parts 2 21st November 2004 07:25 PM
how do you discharge a capacitor? newbie88 Everything Else 5 11th February 2004 05:57 PM
