Understanding Class-B Tr Dissipation graph
Old 4th January 2013, 06:03 AM   #1
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
Question Understanding Class-B Tr Dissipation graph
Vs= 70V, Load=4Ω
circuit
Q: Why the power curve was parabolic?
i.e. low and high output voltage has low dissipation.
Old 4th January 2013, 06:08 AM   #2
Andrew Eckhardt is offline Andrew Eckhardt  United States
P=Volts X Current
all current no volts, no power
all volts no current, no power
When the transistor is supplying lots of current with lots of volts still across it, dissipation is high.
Old 4th January 2013, 06:09 AM   #3
Ian Finch is offline Ian Finch  Australia
You know it's copyright material so why post the graph here?
Ian
Old 4th January 2013, 07:27 AM   #4
kroto's Avatar
@Ian : I've change the image now. thanks.
@Andrew :
the LTspice formula to express Transistor Q1 dissipatioan is as follow:
V(Vcc,out)*Ic(Q1) + V(Vin,out)*Ib(Q1)
what is V(Vcc,out)? is that mean V(Vsupply-Vout)?
if I want to calculate power dissipation at output=10V,
then it would be :
V(70-10)*2.5A = 150W + V(Vin,out)*Ib(Q1) [which is low enough]
that should be correct, right?
Old 4th January 2013, 07:38 AM   #5
That's right. That's also why an amp with 70v rails designed for a 4 ohm load will have many parallel output devices.
Old 4th January 2013, 10:25 AM   #6
DF96 is online now DF96  England
then it would be :
This appears to be a DC calculation. Fine for a servo mechanism, but for an audio amplifier you need to do an AC calculation and average over a complete cycle. To do this properly involves some simple calculus.
Old 4th January 2013, 10:29 AM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Now throw in driving a reactive load like a speaker where the voltage is out of phase with the current. There will be situations where most of the voltage is across the transistor and most of the current flows at the same time. Once the instantaneous die temperature gets to critical it's sayonara! And for BJT's there is secondary breakdown.......
All the trouble I've ever been in started out as fun......
Understanding Class-B Tr Dissipation graphHide this!Advertise here!
Need help understanding class B output stage capacitor variations dunndatt Headphone Systems 1 1st October 2010 06:21 PM
New idea for low dissipation Class A amplifier. Mooly Solid State 69 1st December 2009 11:11 PM
AB class poweramp help understanding ????? prorms Solid State 9 4th August 2007 01:47 PM
Class A sound/AB Heat Dissipation Samuel Jayaraj Solid State 5 23rd October 2003 01:34 PM
tr substitute dexter Solid State 5 29th April 2001 03:53 PM
Copyright ©1999-2017 diyAudio
