How to model stability analysis of a linear regulator such as this?
Old 2nd January 2013, 12:03 AM   #1
Fusion916 is offline Fusion916  United States
Default How to model stability analysis of a linear regulator such as this?
In simulation, what is the proper method to model a stability analysis of the following circuit?
Meaning where do I inject the AC signal and where do I look at the loop gain/phase? Do I need to inject the AC signal into vdc and look at vb? If so, what other modifications do I need to make to my testbench to properly model the analysis?
Old 2nd January 2013, 08:34 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
The most straightforward way (not 100% theoretically accurate, but more than sufficient) is to insert your AC source between FB and the NI input, and look at the ratio of VFB/VNI
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 2nd January 2013, 06:00 PM   #3
What inaccuracies arise from this method?
Old 2nd January 2013, 06:14 PM   #4
jcx is offline jcx  United States
use forum search for Tain Middlebrook LoopGainProbe for some discussions
you can also force the output with a Isource - the impedance curve is related to the feedback factor - severe peaking is a warning sign
load step response gives similar info
Old 2nd January 2013, 06:30 PM   #5
Elvee's Avatar
The loading of the divider by the amplifier's input is not taken into account
Old 3rd January 2013, 03:52 AM   #6
Elvee, do you mind posting a simulation schematic of your test circuit for stability analysis?
Old 3rd January 2013, 07:54 AM   #7
Devilsdance7775 is offline Devilsdance7775  Australia
I bet MicroCAP does it. If you install it and go to EXAMPLES folder than you find something similar ( stability over time, outside temperature, parts parameters deviations and transition events). Must be here.
Old 3rd January 2013, 09:23 AM   #8
Elvee's Avatar
Here it is; the circuit had to be adjusted to display something usable as the original values were too crazy, but the principle remains the same whatever the exact circuit.
Old 3rd January 2013, 06:30 PM   #9
V3 is the AC source correct? And what purpose does the 1n4148 serve?
Old 3rd January 2013, 07:48 PM   #10
Elvee's Avatar
Yes
Displaying a nice downwards sloping curve as expected, instead of an ugly flat one (not connected with simulation issues).
How to model stability analysis of a linear regulator such as this?Hide this!Advertise here!
Another Linear Pass Regulator keantoken Power Supplies 14 13th January 2009 09:33 AM
Modular Linear Regulator TheDriver Parts 0 28th July 2008 08:27 PM
Linear regulator eltonseemann Power Supplies 10 1st November 2007 04:44 AM
Phase Linear Model 700 Gibbi Solid State 123 9th May 2007 05:25 PM
Cascaded Switching Regulator Stability mirlo Solid State 1 12th April 2003 02:23 PM
Copyright ©1999-2017 diyAudio
