How to model stability analysis of a linear regulator such as this?
Old 3rd January 2013, 08:12 PM   #11
jcx is offline jcx  United States
-30 degrees phase margin at the 0 dB gain intercept means its an oscillator, not a regulator
base pullup R is always used in real circuits
the pass Q adds gain depending on load current to the loop so compensation is required somewhere - heavier overcompensation is required for larger load range, C on the reg output has a big impact on stability
Old 4th January 2013, 03:35 AM   #12
Fusion916 is offline Fusion916  United States
Originally Posted by Elvee View Post
Here it is; the circuit had to be adjusted to display something usable as the original values were too crazy, but the principle remains the same whatever the exact circuit.
Hmm, Elvee for some reason the circuit that you posted does not work for stability analysis. I had to put a large series L and large C to the AC source to get the analysis to work.
With that said, I'm finding this setup stable without any compensation. Why is this? I modeled my opamps to have a similar open loop frequency response as in the datasheet of the LM358. Is this because the low gain bandwidth product of the opamp?
Old 4th January 2013, 01:32 PM   #13
Elvee is online now Elvee  Belgium
Elvee's Avatar
Probably some restriction of the simulator you use.
Could be many reasons, transistor not conforming to model, parasitic inductance in the input loop, etc
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 4th January 2013, 03:19 PM   #14
davidsrsb is offline davidsrsb  Malaysia
It simulates stable with Simetrix.
If you add uF level load capacitance, it becomes borderline unstable. This is cured by small series resistance.
This is typical behaviour of this sort of regulator, never use low ESR decoupling
How to model stability analysis of a linear regulator such as this?Hide this!Advertise here!
Another Linear Pass Regulator keantoken Power Supplies 14 13th January 2009 09:33 AM
Modular Linear Regulator TheDriver Parts 0 28th July 2008 08:27 PM
Linear regulator eltonseemann Power Supplies 10 1st November 2007 04:44 AM
Phase Linear Model 700 Gibbi Solid State 123 9th May 2007 05:25 PM
Cascaded Switching Regulator Stability mirlo Solid State 1 12th April 2003 02:23 PM
