Nexgen Vishay Siliconix Gen4 Mosfets can they be used for audio? - diyAudio
Old 1st January 2013, 10:20 PM   #1
Default Nexgen Vishay Siliconix Gen4 Mosfets can they be used for audio?
TrenchFET Gen IV MOSFETs - Vishay/Siliconix | DigiKey
Old 2nd January 2013, 12:18 AM   #2
nigelwright7557's Avatar
The spec seems to suggest not as it only lists switching systems.
However vertical and lateral mosfets are commonly used in amplifiers.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 2nd January 2013, 02:09 AM   #3
expert in tautology
bear's Avatar
reading the pdf datasheet seems to say that these are specifically limited to VERY fast switching applications at unusually low voltages. The current draw seems high, but it is for milliseconds. Linear operation does not seem to be an option.
Also, I didn't look to see if there are complementary pairs.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 2nd January 2013, 02:27 AM   #4
jcx is offline jcx  United States
for linear you actually want some Rdson- small milliOhm values are a bad sign
Old 4th January 2013, 09:51 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Certain types of architecture of vertical fets are not suitable for analog operation. Trench-types are not suitable mostly because they actually have a secondary breakdown like feature and will hot spot and fail. Also Cgd becomes very large at Vds saturation with these devices. Uni-fet is another unsuitable canidate. Look for the differences in capacitance curves along with Rds-on for the different types of devices. Generally, the cellular devices, like Hexfets are more suitable for analog purposes. Also Planer Stripe type fets are very rugged for analog uses, but notice the increased dependency of Vgs vs Id upon Vds for these. I use these with excellent results but only with somewhat sophisticated error correction.
All the trouble I've ever been in started out as fun......
Good Source For Vishay-Siliconix/Motorola 2N5565, or 2N5564 Dual Jfet? NagysAudio Solid State 5 18th February 2011 02:20 PM
Vishay/Siliconix vs. IR irfp150 amt Solid State 2 23rd May 2010 07:20 PM
Vishay Audio Resistors lcsaszar Parts 9 10th June 2008 09:22 PM
vishay s102k super audio resistors ARCHAICAUDIO Swap Meet 11 7th January 2004 10:01 PM
Copyright 1999-2017 diyAudio
