100w to 1000w class ab
Old 12th April 2013, 12:39 PM   #61
Walkalone is offline Walkalone  Viet Nam
Too danger if run this circuit with 2SC5200/2SA1943 at max rail (95V).
Datasheet 2SC5200/2SA1943 show they're have 0.45A@100V@DC. +/-95 will get about 800 ~ 900W@4R, equal 15A current load. This impossible with 8 pairs power output transistors.
More than 15 pairs will to do it.
Old 12th April 2013, 03:32 PM   #62
yehan is offline yehan  Philippines
So what is your recommend voltage and transformer ampere to get 1000 watts rms at 2 ohms load thanks..
For P5000, and what is the voltage bias and current.
Old 13th April 2013, 04:35 AM   #63
Maybe use ON Semi devices to do it. MJL21193/MJL21194.
1000W@2R equal 600W/4R, 350 ~ 400W/8R. The rail is about 85VDC.
Old 13th April 2013, 01:19 PM   #64
Thanks...1000watts for 5pair of mjl? What is the maximum ampere of transformer? For P5000 schem.?
Old 14th April 2013, 05:16 PM   #65
wattaniya is offline wattaniya
this is a powerful amp. already checked with paudio sd18 inch speaker with folded horn bin.25ampere transformer and 85v dc supply .8 pair 2sc/2sa number trannies.
1500w can get with 25ampere transformer.
more rugged amp.
less heat.
Old 15th April 2013, 01:27 AM   #66
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Wink schematic
BRIDGED AMP SCHEMATIC
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 15th April 2013, 01:42 AM   #67
Wink working at night
some crazy diyers working on amps from 10am to 5am next day non stop
gaurav on his ab class sameerx1 packing his dclass
warm regards
andrew lebon
Old 15th April 2013, 04:05 AM   #68
Try DRV134 to get better.
Old 28th April 2013, 11:24 PM   #69
brons77 is offline brons77  Argentina
warm regards
andrew lebon
Diagramas amplificadores - Página 165
TR-3500 yirochi = TR-7007
Old 29th April 2013, 01:57 AM   #70
SERGIODS is offline SERGIODS  Peru
Lightbulb YIROSHI
you mean this contribution:
Amplificador Yiroshi TR3500 Con Super Driver 1500W
Also can be found on FOROSDEELECTRONICA, but closed the topic:
100w to 1000w class abHide this!Advertise here!
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 86 9th May 2018 09:32 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
2 ohm with 100W class AB or D amplifier Hadighorbani Solid State 23 7th June 2012 09:05 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
