100w to 1000w class ab
Old 17th January 2013, 07:37 AM   #51
hadita is offline hadita  Indonesia
hadita's Avatar
Default pcb layout
Originally Posted by nazirdigi View Post
here is the schematic.
hi...nazir share pcb layout please i'am interest to build this amp to handle 2x18" sub low are you recommended...(layout pcb in pdf file post#1).
regard
Old 17th January 2013, 01:08 PM   #52
wattaniya is offline wattaniya
i dont have pdf , so here is the bottom layout in jpeg. dont mirror the image, this is for screen printing.
Old 17th January 2013, 03:03 PM   #53
hadita's Avatar
Ok thanks a lot you are the best diyer's
Old 26th January 2013, 03:04 AM   #54
ahmadfay is offline ahmadfay  Indonesia
ahmadfay's Avatar
This is equal to 1500 watts power yiroshi?
Old 26th January 2013, 03:23 AM   #55
yes its same.
Old 26th January 2013, 03:45 AM   #56
nix is offline nix  Philippines
yes its same.
hi nazirdigi thanks for sharing this amp by the way do you have bridge pcb layout of this hiroshi amp? if you have it please share..thanks again in advance.
regards,
nix
Old 20th February 2013, 11:32 AM   #57
f-recovery is offline f-recovery  Philippines
nazirdi any schematics of the hafler x7 pls.
Old 20th February 2013, 11:36 AM   #58
nazirdi how about the crown bridged xls?is this the same as the CROWN XLS schem?
Old 8th April 2013, 02:56 AM   #59
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Wink full schematic
pcb to come
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 12th April 2013, 12:11 PM   #60
DILIP KUMAR is offline DILIP KUMAR
DILIP KUMAR's Avatar
pcb to come
100w to 1000w class abHide this!Advertise here!
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 83 3rd April 2018 03:15 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
2 ohm with 100W class AB or D amplifier Hadighorbani Solid State 23 7th June 2012 09:05 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
