Old 8th January 2013, 09:31 AM   #31
Originally Posted by sudhir kumar View Post
Without giving more details about quality, real experience, specs etc. you are just throwing these designs on forum. What is the use if you don't provide any detail ?
regards
sudhir.
check the website.
Old 8th January 2013, 09:34 AM   #32
Originally Posted by nazirdigi View Post
very hard to find these bcb's.
do it yourself, if i am throwing this to forum then i will stop sharing to this forum.
atleast can u find this pcb s ? sudhir kumar.
Dear Nazirdigi , Its very good that you are sharing these pcbs to forum , but problem is that ,we don't know any thing about these projects. does these are tested and tried ?does these are your work or copied form anywhere ? does these are copyright free work. So please friend share some more details to make them much useful.
thanks
sudhir
Old 8th January 2013, 09:49 AM   #33
these driver modules not hard to make and test, just diy.
Old 8th January 2013, 09:50 AM   #34
if u dont know the basic , i am very sorry.
Old 8th January 2013, 05:05 PM   #35
vedmitraa's Avatar
Thanks NazirDigi for Megatech boards,
I am intreated in hifi preamp ,sub,board layout and circuit please
Failure in Experiment is key to success .Only right combination is needed.
Old 9th January 2013, 01:27 PM   #36
nice sound, no on off thumbs,
tested with 4 pairs, 50vdc and 93vdc, this amp is for subs, good low, some images after test.
50mv dc offset.
Old 9th January 2013, 01:35 PM   #37
this is high-end preamp .
Old 9th January 2013, 02:00 PM   #38
Vostro is offline Vostro  Madagascar
Vostro's Avatar
Thanks for the share,
Vedmitraa, if you decide to build this preamp, please report back on your impressions
Old 9th January 2013, 02:32 PM   #39
Riff is offline Riff  Indonesia
Riff's Avatar
great Nazirdigi for sharing Megatech preamp board...
pre tone sub & SB3 is difference right?
btw...have you Copper+Layout SB3 in PDF?
RiffMawon@Live.com
Old 9th January 2013, 03:11 PM   #40
pdf shared post 37 see down.
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 53 1st April 2013 07:18 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
2 ohm with 100W class AB or D amplifier Hadighorbani Solid State 23 7th June 2012 09:05 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright ©1999-2013 diyAudio
