Bipolar capacitors for decoupling?
Old 30th December 2012, 08:41 PM   #1
rhythmsandy is offline rhythmsandy
Default Bipolar capacitors for decoupling?
I have few Elna silmic2 with 35v rating but my amp psu is +/-55v can I use two capacitors connecting the back to back negative pins so that I can use them as Bipolar and even increases the voltage rating of it?
Old 30th December 2012, 08:50 PM   #2
jcx is offline jcx  United States
Default bipolar won't have "negative" pin - no front/back
no, in reverse the polar type only block ~1V so the rating of the pair would only be 35 VDC
in series you can add the V rating - if you provide some way to balance the V across the pair
if you do mean bipolar, full thickness oxide grown on both foils then you still need some V balancing technique to use at higher than individual cap rating
Old 30th December 2012, 08:54 PM   #3
so its better to use two of them in series to get better output voltage but overall the capacitance will be half of the original rating of the cap..
Bipolar capacitors for decoupling?Hide this!Advertise here!
Gainclone - why use large value decoupling capacitors ? ash_dac Chip Amps 28 6th February 2016 06:36 PM
TDA1541A decoupling capacitors value Zoran Digital Source 25 22nd April 2010 09:18 PM
Bipolar Caps for decoupling? jtsaudio Parts 7 29th March 2009 11:35 AM
Film capacitors for decoupling rotation Parts 4 6th November 2007 08:02 PM
Good Coupling and Decoupling Capacitors fmak Solid State 42 20th June 2004 08:05 AM
