small, but high quality amp small, but high quality amp - Page 2 - diyAudio
Old 13th November 2003, 04:26 AM   #11
hitsware is offline hitsware
what will be the Zin ?
Old 13th November 2003, 04:32 AM   #12
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
About 1.5k.
se
Old 13th November 2003, 04:38 AM   #13
will your generic 'red cd' put out a good 2V into 1.5K?
Old 13th November 2003, 05:25 AM   #14
Steve Eddy's Avatar
If it's output impedance isn't unusually high. The transformer in question is optimized for a 150 ohm source impedance. So if you're in that range you're looking at a little under 1dB loss so you'll get about 1.82 volts at the primary and about 9 volts at the secondary. So you can still get close to 5 watts at the end of the day. Which would be a difference of just over 1dB compared to 6 watts.
By the way, I just posted the 1:1 headphone version here:
http://www.diyaudio.com/forums/showt...145#post264145
se
Old 13th November 2003, 10:18 AM   #15
SDF is offline SDF  France
As soon as simple and with the same Mosfet:
http://perso.wanadoo.fr/jm.plantefeve/sche.html
Old 13th November 2003, 10:52 AM   #16
Dirk is offline Dirk  Belgium
I would call a 10W SE class A amplifier less than small and portable
Anybody a discrete high-quality low-power suggestion in class AB?
Dirk
Old 13th November 2003, 04:01 PM   #17
GregGC is offline GregGC  Canada
Default Re: small, but high quality amp
Originally posted by Sukandar
I'm looking for schematics or general design remarks about amp designs for portable gear (not necessarily battery powered though)
So far I've been playing around with those hybrid modules like the LM1875 or TDA1562 but I'm not really happy with their sound so I'm looking for alternatives, even if it means going discrete
hope this is the right place to ask
thanks
Sukandar
What exactly didn't you like in the way LM1875/3875 sounds (the version you build of course)?
I beleave the LM3875 is the perfect candidate.
Old 13th November 2003, 05:35 PM   #18
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: small, but high quality amp
thanks
Sukandar
Hi Sukandar,
May be the Son of Ampzilla or the Grandson.
http://home.kimo.com.tw/skychutw/ampzilla/index.html
Must be possible to use FETs for the inputstage like 2SK389 & 2SJ109....
Old 14th November 2003, 07:39 AM   #19
mozikluv is offline mozikluv  Philippines
Send a message via Yahoo to mozikluv
hi sukandar,
how about trying this, AN7178. its a dual channel 12 pin amp rated at 5.8w per channel. you can power it from 9v to 16v.
"none but the brave deserves the fair" shakespeare
Old 14th November 2003, 10:19 PM   #20
till is offline till
Banned
sukanda,
please give more information on the use of the device you want to build. The smallest portable amp i build so far is battery powered, about 1*1*2 cm , 1W based on SSM2211 SMD chip.
A real high quality amp is something like http://www.passdiy.com/projects/zenv4-1.htm and this is some kg, not portable anymore, and i doubt you have portable speakers to have any advantage on such an amp in mobile use.
small, but high quality ampHide this!Advertise here!
Small but high quality tweeters? Tenson Multi-Way 3 22nd January 2007 03:55 PM
Small, Inexpensive High Quality Film and Foil Caps dsavitsk Parts 5 7th February 2006 01:25 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
High Power High Quality Digital Amp aspycaudio Digital Source 0 6th December 2003 09:49 AM
Copyright ©1999-2017 diyAudio
