Old 29th December 2012, 04:43 PM   #1
Default Need Help in Houston
Looking for some help here in the Houston area. One of my Muse 175 monoblock amps has an intermittent problem with a connection on the negative binding post. Looking inside of the chassis, the solder joint *looks* OK, but output comes and goes as the post is moved from the outside. There's a resistor soldered between + and - posts and I'm guessing that the lead to the negative post might be broken inside of the ceramic body causing an intermittent connection. Looks like a very simple repair if one knows what they are doing, but that leaves me out. I simply don't know enough to have the confidence to mess with this and would like to find someone local that could help me with it.
Thanks,
Bobby
Howdy from Houston countrysquire Introductions 3 29th December 2012 05:14 PM
Houston, We Have A Problem....... cwoodall Parts 12 13th September 2005 03:31 AM
Hello from Houston, Texas! mista2 Introductions 9 23rd April 2005 04:43 AM
Intro from Houston soundsgoodtome Introductions 2 2nd November 2004 03:27 AM
Houston,we have problem... Upupa Epops Solid State 47 10th October 2004 12:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
