Old 29th December 2012, 09:20 AM   #11
Originally Posted by peranders View Post
What sort of calculations are these? 3.6 amps will give you 50 Watts into 8 ohms if we talk class A.
It's pretty simple:
Irms = 3.6/1.414 = 2.546 A
P = I^2*R= 2.546*2.546*8 = 51.84 watts
no. the formula will be: (3.6x2)x(3.6x2)x8/2=207W
accordind to your calculation. the First watt F5 will give 6.7W class A at 8ohm.(1.3A bias) acctualy it gives 27W
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 29th December 2012, 09:31 AM   #12
Electrons are yellow and more is better!
peranders's Avatar
3.6 amps is the bias and is the same thing as the peak current (in class A) and the rms current is 1.414 times lower. Do we talk about the same thing here?
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 29th December 2012, 09:35 AM   #13
peak current is TWICE the bias
Vivaldi8 speakers
Old 29th December 2012, 09:40 AM   #14
from F5 manual:
For this sort of circuit, a 1.3 amp bias means that the amplifier will operate Class A to 2.6
amps of output current. To understand this, imagine a condition where Q3 and Q4 are
idling at 1.3 amps, so that all the current is going from the V+ voltage rail to the V- voltage
rail, and none is going through the loudspeaker.
The power of 2.6 amps into 8 ohms is I^2 * R, or 2.6 * 2.6 * 8 = 54 watts. This is the peak
value, and the nature of an undistorted sine wave is that the peak wattage is twice the
average, so this circuit would operate 27 watts average Class A into 8 ohms. At currents
above 2.6 amps one of the transistors will shut off, leaving the other to continue to increase
beyond the 2.6 amps in what is known as Class AB.
Vivaldi8 speakers
Old 29th December 2012, 09:46 AM   #15
KatieandDad's Avatar
So 1.3A is giving you 27W Class A from the F4.
With the Aleph 4, 2.5A bias gives you a true 100W RMS Class A.
Old 29th December 2012, 09:57 AM   #16
katie. class A power have nothing to do with your rail voltage.
it is, (2.5*2)*(2.5*2)*8/2=100W class A power at 8ohm.
Vivaldi8 speakers
Old 29th December 2012, 02:22 PM   #17
check this thread how nelson calculates the class A power..
Leaving Class A? Martin Colloms vs Nelson Pass
Old 29th December 2012, 02:35 PM   #18
djk is offline djk
djk's Avatar
I would build it with a tiered power supply.
With a ±20V supply for the low rail the idle would only be 144W, that could be done with only two or three pair of IRFP240/9240.
Candidates for the Darwin Award should not read this author.
Old 29th December 2012, 03:11 PM   #19
bobodioulasso's Avatar
Originally Posted by rhythmsandy View Post
according to nelsons pow calculations 3.6A Bias
( 3.6 x 2 )^2*8 = 414.72W peak and for continuous 293W in 8 ohms
414w peak is 207w average. 60V is about right for 200W/8ohms. Air forced cooling Mandatory.
Old 29th December 2012, 07:03 PM   #20
I would be using the IGBT heatsink and each heatsink will have 4 Hexfets dimensions
heatsink width 5 inch length 6 inch depth is also 6 inches... wouldnt that be sufficient?
how do I calculate how much each hexfet is dessipating the heat?
200W Class A Power Amp wengtech Elektor 7 17th May 2013 07:06 AM
L-20 200w class b amp ljm_ljm Solid State 5 3rd October 2011 03:04 PM
200w class d WTOAK33 Class D 6 19th July 2011 03:52 AM
200W in 8 Ohms Class D amp wanted Session Class D 5 8th October 2009 07:08 PM
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 07:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
