n channel amp temperatur - diyAudio
Old 12th November 2003, 09:15 PM   #1
Default n channel amp temperatur
hi
i've build the n-channel amp from www.aussieamps...... with my own pcb. It works great. B]But is it true, that the heatsink temperatur is without load 50-60 degrees??[/B]
i've not matched the mosfets, so is this the problem?
thx a lot
Old 12th November 2003, 09:41 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Re:
I have no exact temp. measurement yet, but I do not think mine is more than ~ 40 C, when bias is set as instructed.
(BTW, do you have spare PCB's?)
Arne K
Don't believe everything you think...
Old 12th November 2003, 09:45 PM   #3
Default PCBs
the pcbs are selfmade.
tomorrow i can post a pic. or if you want a .brd file.
i check bias tomorrow too.
thx
Old 13th November 2003, 11:11 AM   #4
LBHajdu is offline LBHajdu  United States
The idol dissipation of this amp is 42watts. Most class A\B amps would consider that high, however this amp is not really biased that high (300mA), its just that the rails use a high voltage +-70v. It would be a good idea to see what effect changing the bias has on the sound.
The heat sink temp is what ever your heat sinks say it is. The Bigger the heat sink the lower the temp. To find out what the idol dissipation temp is just take 42 and multiply it by the thermal coefficient of the heat sink. The amp will dissipate more when its playing music. If you think something is wrong with the bias just keep an eye on the .33ohm resistors. If there is more the .033V across it then you bias is off.
How do you think this amp sounds? Could you compare this amp to something else?
Were all waiting for pics.
Old 13th November 2003, 07:28 PM   #5
Lightbulb here is my pcb
here is my own pcb.
i've made it with eagle.
it works great, but keep a look at Q1, Q16 and Q13.
there was some trouble with them because of a false pinout in my pcb. i've corrected this, but still keep a look.
i'm creating currently some new pcb with a protection circuit witch is a little smaller. hear from me later.
feel free to ask.
best regards
ps: betterquality pics on inquires
Old 13th November 2003, 08:19 PM   #6
DIY !
Cobra2's Avatar
Default Re:
Hi!
If you do a re-design, you could moove the bias-compensating transistor....so it is closer to the output devices, (it will probably need extension-leads anyway to reach ontop?).
See: http://www.diyaudio.com/forums/showt...0663#post80663
Arne K
Old 13th November 2003, 08:58 PM   #7
in my amp i've connect the bias-compensating transistor with a cable to the pcb. it is on top of one of the output mosfets.
when i've my digicam back i would take some pics ofthe real pcb and amp.
best regards
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 05:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 11:10 AM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 06:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 08:48 PM
Copyright 1999-2017 diyAudio
