'Soft-on' a good idea? - diyAudio
Old 28th December 2012, 04:09 AM   #1
Zoodle is offline Zoodle  Australia
Default 'Soft-on' a good idea?
Hi DIYers,
I finally built something (making use of advice received here, thanks
I thus have a -/+15 power supply (LM317/337) fed by a dual 15v (nominal) AC toroidal (50VA total). This supplies a small device that has five dual op-amps (it's an electronic crossover).
At the moment, there is no switch, I just plug the power cord into the wall.
I'm slightly concerned that the crossover and/or the power supply circuit might be receiving a 'rude awakening' when I plug the power cord into the wall.
I will be making one for someone else, and want to do a good job in every way, and that brings me to the following situation:
The device needs to last well in regular use. When not in use, the transformer's primary must be isolated from the mains (not negotiable).
So, IYO, should I provide some kind of time delay relay, which connects power to the crossover after a couple of seconds? Or is it better to place it after the transformer (IE before the PSU circuit)?
What are the issues (if any) when connecting/disconnecting a dual rail supply? Do you make/break the ground instead (or is that a bad idea)?
Will be grateful for the benefits of your experience.
Good Soft Distortion Tesla88 Tubes / Valves 16 24th December 2012 03:09 PM
Hyperx soft start any good for valve amp situation? data Tubes / Valves 0 25th September 2011 07:33 PM
I think I have a neat, simple and easily implemented idea for a soft start circuit hifinerd Solid State 54 8th October 2010 01:05 PM
Is this a good idea? AC439 Multi-Way 0 30th December 2008 07:48 PM
good free/soft ware for Mac? brymway Multi-Way 1 3rd January 2004 12:05 AM
Copyright 1999-2017 diyAudio
