Unity gain solid state buffer - Page 3 - diyAudio
Old 15th January 2013, 08:30 PM   #21
Piercarlo's Avatar
Originally Posted by Mike H View Post
Yep sounds familiar ....
Explain it! :-)
Hi
Piercarlo
Analysis, ideas, projects... audio-electronics madnesses
http://piercarlo-audioelettronica.blogspot.it
Old 16th January 2013, 04:35 PM   #22
Mike H is offline Mike H  United Kingdom
Mike H's Avatar
Murphy's Law?
Old 16th January 2013, 04:43 PM   #23
Mike H's Avatar
As a matter of interest which pair were deciding to act like an SCR?
Old 16th January 2013, 09:09 PM   #24
Piercarlo's Avatar
As reported in the first schematic posted at the start of this thread, QGN5 with QFLOAT1: collector of one transistor is wried to the base of the other in a riing fashion.
Piercarlo
Old 17th January 2013, 12:38 PM   #25
Mike H's Avatar
Oh right OK.
Old 19th January 2013, 06:52 PM   #26
Piercarlo's Avatar
Circuit rebuild and retested; after adding a start resistor and a compensantion for cutting off an otherwise huge (and harmful) bandwidth. Now seem work fine.
Piercarlo
Old 24th January 2013, 06:50 PM   #27
Struth is offline Struth  Canada
Banned
Hi Guys
With everything bootstrapped, it seems like the main goal is to reduce input capacitance and increase input impedance. R-IN seriously degrades the latter and could be much higher if you needed a really high z-in.
Otherwise, Doug Self showed how to achieve high z-in using just BJTs and liberal bootstrapping in his "Small Signal Audio Design" book. Bootstrapping has been around since tube days. Noise can sometimes be compromised using these methods and distortion more often is.
There are simpler ways to have a good signal buffer with low distortion and reasonable signal amplitude handling. But... like you say, sometimes you just have to try something for the sake of trying.
Have fun
Kevin O'Connor
Old 25th January 2013, 10:17 PM   #28
Piercarlo's Avatar
Originally Posted by Struth View Post
Hi Guys
With everything bootstrapped, it seems like the main goal is to reduce input capacitance and increase input impedance. R-IN seriously degrades the latter and could be much higher if you needed a really high z-in. r
Thanks for your considerations but the goal is not having an high input-z for itself (although the real INNER input Z is above 10 Megaohm: R-In is just for locking to ground DC the input coupling capacitor and may be chosen of any value below a couple of Megaohm).
Exactly! :-) One "psychological" goal is to show how a circuit can become complex if someone want to achieve without feedback the (near) same result obtained WITH feedback - that however is not really absent! :-) Transistor used are of the cheapest and common type but however the circuit is neatly more expensive of a simple voltage follower implemend with any low cost good audio operational amplifier... ;-).
Piercarlo
Old 27th January 2013, 12:00 AM   #29
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Enclosed circuit was used in condenser microphones for many years
Old 27th January 2013, 12:13 AM   #30
dimitri's Avatar
This circuit can be found in almost every mixer from Ma*kie
solid state, unity gain preamp lordearl Solid State 5 29th May 2010 07:10 AM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 09:02 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 09:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 10:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Copyright 1999-2017 diyAudio
